Old 20th April 2008, 05:58 PM   (permalink)
Default LCD Identification?
Hello
I got hold of a LCD display that I would like to use for a prodject im doing, the problem is I cant find any information on it, Ive done a continuity test on the terminals and have found that term 3 is ground and terns a/k are for the backlight but other then that im stuck can anyone help?
johnl69 is offline
Old 20th April 2008, 06:03 PM   (permalink)
hi
Get the datasheet for the Hitachi HD44780 LCD.
It looks like a 2 * 16 LCD.
eg:
http://home.iae.nl/users/pouweha/lcd/lcd.shtml
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 20th April 2008, 06:31 PM   (permalink)
Originally Posted by ericgibbs
hi
eg:
Thanks for that
How would I test it? do I simple connect the vss and vcc to the staed pins and then put an input to bus line and see if any characters appear?
johnl69 is offline
Old 20th April 2008, 07:04 PM   (permalink)
Originally Posted by johnl69
Thanks for that
No, to get any characters you need to feed it correctly and exactly, there are plenty of examples about - including my PIC tutorials. You can download a good article (actually a two part series) from the EPE website.
Old 20th April 2008, 07:05 PM   (permalink)
Thanks for that
I am afraid its not that simple.!
It requires to be driven from a PIC or MCU, needs initialising in the correct sequence before you can write characters to it.
Read thru that link I posted, it will help..
Eric
PIC tutorials:
Old 20th April 2008, 07:18 PM   (permalink)
Thanks guys ill do a bit more reading,
What Pic is required to run this display can it be done with a PIC16F84A?
johnl69 is offline
Old 20th April 2008, 07:28 PM   (permalink)
I believe that any pic, having enough i/o pins will do. Not sure about 16f84a, but perhaps. E.g. At89s2051 can do as a microcintroller, having 2 bidirectional i/o ports - 1 pin (15 i/o pins in total).
lexter is offline
Old 20th April 2008, 07:36 PM   (permalink)
Originally Posted by lexter
I believe that any pic, having enough i/o pins will do. Not sure about 16f84a.
Perfectly fine, you only need six (or seven) pins - my tutorials use them all on one port, with a pin spare.
Old 20th April 2008, 07:56 PM   (permalink)
Yep its a standard pinout 1-14....with 15 and 16 being the LED backlight power. Looks like theres already two resistors in series with it, so I suspect is the usual 4.2V @ 150 mA.
Inconsistency is the key to flexibility!
Blueteeth is offline
Old 20th April 2008, 10:39 PM   (permalink)
Thank alot guys
I read those tutorials on EFE and hooked up a breadboard mockup like it says and it works fine now to sort out the pic
johnl69 is offline
Old 20th April 2008, 11:27 PM   (permalink)
Thank alot guys
The EPE tutorial is really good!.
LCD 2x16 Demo for the Unicorn (18F4550) blueroomelectronics Micro Controllers 21 31st October 2008 05:17 PM
LCD Bargraph (fuel gauge) karenhornby Micro Controllers 10 10th April 2008 06:20 PM
Atmel, assembly:displaying on lcd Haidy Micro Controllers 13 11th February 2008 09:13 PM
<--noob :) Need help with a Voltmeter/VU Bargraph Lcd display idea Derick2k Electronic Projects Design/Ideas/Reviews 2 5th February 2008 11:39 PM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 10:20 AM
