Old 20th April 2008, 03:34 AM   (permalink)
Default Help with simple 555 circuit?
Hey guys,
I have built a 555 timer circuit, which in turn drives a TIP41C to power a flyback. http://tacashi.tripod.com/elctrncs/555sstc/555sstc.gif is the circuit, exept i swapped out the said transistor for the TIP41C equiv. The problem is the output arc is VERY weak, less than 1cm. I have 12V @ 4A input, and that gave me VERY big arcs with a 2N3055 circuit, so i dont know why it isnt doing that here. is there any changes i need to make to this circuit to accept the other transistor? I feel that the transistor isn't letting enough power through, but i have no idea how to change this. Also, apparently you can chnage the 1K and 2.2K resistors, and 10nf cap to vary the freuency of the 555, what are safe rsistances to stick with, since i dont really wanna blow anything up
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 20th April 2008, 05:16 AM   (permalink)
BTW i tried 2 different flybacks, so its not my flyback. Also this is for a singing arc, so the audio goes into pin 5 of the 555 with a .1uf cap across + and -.
things is offline
Old 20th April 2008, 05:24 AM   (permalink)
Your link to the circuit shows nothing. Please copy the schematic and attach it here.
a 2N3055 has a max allowed collector current of 15a.
a TIP41 has a max allowed collector current of only 6A so maybe it breaks in the circuit.
audioguru is offline
Old 20th April 2008, 05:32 AM   (permalink)
Oh woops....
Here is the circuit i made...
things is offline
Old 20th April 2008, 06:25 AM   (permalink)
well the sound works fine, i just really need to get more power into this arc, it can barely keep itself together, and the transistor is getting very hot as it is....
things is offline
Old 21st April 2008, 08:01 AM   (permalink)
No one has any idea?
things is offline
Old 21st April 2008, 03:39 PM   (permalink)
The transistor will be hot if it conducts too much current for its rating.
It will also be hot and the output power will be low if the transistor does not have enough base current so it does not conduct fully.
The 50 ohm base resistor gives the transistor a base current of 180mA when the supoply is 12V. Then it conducts well when its collector current is no higher than only 1.8A.
The 555 will fry if the base resistor has its value reduced.
If the TIP41 transistor is replaced by a TIP147 darlington transistor then the circuit will work better.
Old 17th May 2008, 05:06 AM   (permalink)
Be sure to isolate the transistor with a suitable heatsink, or you will fry more than the circuit. Are you building a stun gun, electric fence or CRT/flyback tester?
shokjok is offline
Audioguru Please See My Simple PreAmp Circuit Gayan Soyza General Electronics Chat 11 8th May 2007 03:58 AM
Simple Integrator Circuit ThermalRunaway General Electronics Chat 3 21st March 2007 09:29 PM
Simple flatulence sound generator circuit? HarveyH42 Electronic Projects Design/Ideas/Reviews 4 29th July 2006 06:37 PM
Need A Simple Alarm Clock Circuit Handiplus Electronic Projects Design/Ideas/Reviews 0 29th March 2004 03:02 PM
I need a simple low power LED flasher circuit alanzhao General Electronics Chat 5 25th January 2004 06:20 AM
