Old 19th April 2008, 10:34 PM   (permalink)
Default Not all PCB stock is created equal.
I have been buying my PCB stock from Electronic Goldmine. Up to now I have been quite happy with it. I etched a board on friday using some new DS stock.
The problem is when you do an rework (remove a part) the foil lifts. When I get back to school on monday it is going in the trash. I will post the EG part number so others can advoid it.
I prefer the copper to say put.
3v0 is offline
Old 20th April 2008, 09:06 AM   (permalink)
I've had a bad batch of Photoresist before. Same supplier, same manufaturer but two of the boards had a kind of shadow on them which wouldn't develop or clean off.
Took me a while to convince them that there was a problem but was replaced after a bit of quibbling.
That reminds me - I must whittle down some of my PCB stock - I keep ordering it and putting it away then forgetting its there and ordering more.
picbits is offline
Old 20th April 2008, 02:43 PM   (permalink)
True. FR4 comes in various temperature ratings (Tg), which is the glass transition temperature. Here are two references. The first has a nice table of values. Note the low Tg spec. is around 126 to 168 °C. One source states "most" are 150°C, but clearly something with a Tg of only 126°C can meet that spec. too.
John
http://www.rogerscorporation.com/mwu...am%20Cust..pdf
http://www.rogerscorporation.com/mwu...swerDraft4.pdf
jpanhalt is offline
Old 20th April 2008, 05:56 PM   (permalink)
I thought it was a function of what adhered the Cu to the PCB?
speakerguy79 is offline
Old 20th April 2008, 06:20 PM   (permalink)
Could be that too. I have noticed it is easier to pull the copper foil off some FR4 stock than others. However, the references (search on FR4 Tg) make it clear that the Tg of the board is very important in the lifting of traces during soldering and repair. With lead-free solder, it is a particular concern, and we may see much greater availability of high-Tg FR4 in the future. John
jpanhalt is offline
Old 20th April 2008, 06:53 PM   (permalink)
It is very easy to make cuts across a trace and scrape the copper off this PCB. With other types I have you have to work at it. I am thinking it is the adhesive. Since this stuff is surplus it may have even been a bad batch.
I am used a temperature controlled iron set to 250C.
The base material is off white. The other stock I have are the greenish and the brownish types.
3v0 is offline
Old 20th April 2008, 11:56 PM   (permalink)
I've been using goldmines single-sided, cut with scissors stuff for a couple of years without a problem. Re-worked the hell out of an RGB LED board a couple of weeks ago, traces stayed down. I have some really thick board, don't remember where I picked it up, but it's very weak glue. I was using a marker for resist back then, so very thick traces. Pads would lift with the tip of the iron, had to try and slide it off...
I've got some of Goldmine's double sided, but avoid doing doubles. but know I'll have to eventually.
HarveyH42 is offline
Old 21st April 2008, 01:24 AM   (permalink)
I like the Goldmine scissor cut for most single sided work.
The bad DS board has what looks like white plastic for a substrate.
3v0 is offline
Old 21st April 2008, 04:03 PM   (permalink)
The SKU number for the board is G2626
Detailed Description
Prime double sided copper clad glass epoxy material for making PC boards. Thickness: .032". Size: 4" x 8". G2626
Prime
It looks like G2628 may be the same stuff.
The good sissor cut SS board is G15698
Thet have better DS stuff but do not have the number at hand. Could be they replaced with the poor stuff.
Should not complain too much it was surplus.
3v0 is offline
PCB design lektro Electronic Projects Design/Ideas/Reviews 4 19th April 2008 03:28 PM
PCB layout help dbtoutfit Electronic Projects Design/Ideas/Reviews 26 19th April 2008 04:17 AM
PCB design karenhornby Electronic Projects Design/Ideas/Reviews 12 22nd February 2008 08:21 PM
Making a PCB matthewwren Electronic Projects Design/Ideas/Reviews 1 29th January 2008 01:09 AM
need help finding a PNP transistor. Melissa Datasheet/Parts Requests 3 13th October 2006 02:59 PM
