Old 17th April 2008, 10:21 PM   (permalink)
Skara is on a distinguished road
Question Run multiple motors off a single power source? & Slow them down?
I'm in the process of starting a sculpture project that I plan to have move around a bit by having parts of it slowly rotate.
So far, I've taken apart a $15 drill and tested it out. It works, but it's... really really fast. I think I need to buy some kind of speed controller?? Is this right?
I need a way to make it go really slow, and I think it'll be more likely to move bigger objects this way without burning up, no? What do I need to buy and how might I hook this up?
Also, I'll have multiple motors all going at varying speeds (but all slow). Maybe 2-20 RPM, if that makes a difference. Some motors will probably be those little dinky motors the size of a thumbnail for very small parts.
As for weight, it will be made out of varying types of wood. I would preferably have the entire thing rotate slowly, but if that won't work that'd be ok. Each piece might be anywhere from 1/2oz to 2lb. Probably nothing bigger than that.
Also, how can I attach multiple motors of varying sizes together and run them off a single wall outlet. What do I need to make this happen?
Thanks for any help!
Skara is offline   Reply With Quote
Old 17th April 2008, 11:06 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
If you slow down an electric motor electrically without a tachometer driving a speed controller then it won't have any torque. It needs torque to start and if the load increases.
You need gears or pulleys to slow it down.
Old 17th April 2008, 11:27 PM   (permalink)
Ah.. Thanks. Alright, gears and pulleys. How, exactly, does this work? Is there some beginners reference with diagrams somewhere I can read??
Also still wondering about the power source question.
Old 18th April 2008, 12:08 AM   (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
I assume you now how a lever works? More force over a small distance can be turned into less force over a longer distance? Same thing with gears and pulleys. THey are just round levers- if you spin a smaller gear (or wheel) once, it will have moved around it's circumferance less than a larger wheel. But if you grab something like a huge steering wheel, it's takes less force to turn than a smaller steering wheel because the lever arm (radius from center to edge) is longer. But to move the same angle, you must move farther along the circumferance when you turn it (travel more distance).
NO, that picture isn't me so don't bother asking if we can be friends.
Old 19th April 2008, 12:54 AM   (permalink)
Ahem. Ah. Well, that's basic. Thanks.
I guess I'll toy around with that for a while.
Old 19th April 2008, 01:15 AM   (permalink)
Experienced Member
Dean Huster is just really niceDean Huster is just really niceDean Huster is just really nice
From the "surplus electronics" catalogs, you can buy motors attached to gear boxes that will have the torque and low speed you need for most project.
Dean
R.I.P.
Dean Huster is offline   Reply With Quote
Old 19th April 2008, 01:31 AM   (permalink)
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
Search e-bay for gear motor. There are 461 of them on the US site. Here is one example:http://cgi.ebay.com/One-DC-12V-12-V-...QQcmdZViewItem
At the speed you are talking about, there really is no substitute for a gear motor -- even a clock drive is a gear motor. John
jpanhalt is offline   Reply With Quote
Old 19th April 2008, 10:32 PM   (permalink)
Experienced Member
Hank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of lightHank Fletcher is a glorious beacon of light
Something like a powerful window or windshield wiper motor would work well, but even with their own gearing, you're still looking at about 50 to 100 RPM. To get closer to your goal of 2 to 20rpm, you could use one of those types of motors with a further mechanical advantage through a couple pulleys, maybe a 5:1 ratio or greater. You could make the pulleys yourself if you've got a lathe, or you could buy heavy duty ones they actually use in lathes from a hardware store (and a belt, too!). This would be a good way to get the speed you want, and would be quite a robust solution - this could easily rotate a 200lb sculpture from 12V (with enough current), presuming the rotation is around the centre of mass and z-axis.
For smaller parts, use the same gearmotors with less power. For even smaller parts, use even smaller gearmotors, such as those available from hobby robotics sites:
http://www.robotshop.ca/home/product...ors/index.html
Hank Fletcher is offline   Reply With Quote
Old 19th April 2008, 10:44 PM   (permalink)
Experienced Member
Sorry, I hadn't noticed that the largest part you have to move is only 2ibs. For that weight, and presuming rotation in any axis and at most 20rpm, hobby robotics motors will be good enough (and generally on par or cheaper than the $15 you've spent on your drill). The only caution I can recommend is that if you're rotating a large, oddly shape piece, and not from its centre of mass, that this could put a lot of strain on the gearmotor output shaft. In that case, you'll want to beef-up the connection with a bearing that will take most of the load that would otherwise be perpendicular to the shaft.
Old 19th April 2008, 11:18 PM   (permalink)
Experienced Member
gerty is on a distinguished road
A friend just finished a project ussing a motor from from a barbeque grill. It turned at the proper speed (gear reduction) and was rated continous duty.
gerty
gerty is offline   Reply With Quote
Old 20th April 2008, 04:08 AM   (permalink)
Hm. yeah, I've got a little hobby motor, but it turns so fast I don't see how I could ever get it slow enough.
I do have a lathe; what materials are appropriate for a pulley? Could I use scrap wood or should I go with a heavy plastic?
Also, do you have any tips for making a belt?
Old 20th April 2008, 04:41 AM   (permalink)
Experienced Member
things is on a distinguished road
Just grab a worm gear and mount it on a motor, they are very slow, but at a fair bit of torque
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline   Reply With Quote
Old 20th April 2008, 11:01 AM   (permalink)
Experienced Member
Worm gears work great for slow speed and they effectively are auto-braking. That is, it is extremely hard (if at all possible) to turn the motor by turning the output shaft. On the downside, layout is more critical than with spur gears and they impart a 90° shift.
A pre-made gear motor, such as the BBQ grill would still be my first choice for slow speed and quiet operation. The planetary gear ones are probably the most quiet and slowest. Cheap, import winches (like at Harbor Freight) are another source of planetary drives and have very slow outputs. Old clockworks (many suppliers on the Internet) will give you three choices of speed (1 rpm, 1 rph, and 1 or 2 rpd.
If you want to go with pulleys/sheaves to get a second stage of speed reduction, these sources may be helpful:
http://www.mcmaster.com/
http://sdp-si.com/catalogs.htm
Check under the term "sheaves" as well as pulley. Some places are particular about that term, others are not.
John
Edit: Forgot the question about materials. Delrin (acetal) is a great plastic for such purposes. Round belts are easy to work with and quiet. The sheaves/pulleys are a little harder to machine for them though.
Old 22nd April 2008, 08:52 AM   (permalink)
Experienced Member
grim is on a distinguished road
for something fairly light duty like this, have you considered Lego?
not the toy stuff, but the grown up engineering experimentation and development system (ok, it's still a toy really)
motors, gears, everything you need, and it all fits together with no tools.
linky
Transformers are work
Electronics is a hobby
grim is offline   Reply With Quote
Old 22nd April 2008, 10:13 AM   (permalink)
Experienced Member
Cheap, surplus gearmotors are the way for you to go, but they still might be slightly too fast for what you want. Oooo... you have a lathe?! Scrap wood can make for some nice pulleys. If you ever want to pay to class it up, aluminum can make some really nice pulleys (but expensive!).
Elastic bands (thick, wide ones) make good belts. Larger belts can be made from surgical tubing. Shoelaces and even just good old cord works, too. Whatever you use, you want to make it stretch just a bit to get it over the groove in your pulleys. Make sure it doesn't have to stretch so much that there's undue stress put on the motors' shafts, though (for instance, when using surgical tubing).
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 27th August 2007 11:05 PM
Power Mosfet drive techniques Optikon General Electronics Chat 8 20th November 2003 11:50 PM
Multiple Input power sources... Appleon Electronic Projects Design/Ideas/Reviews 0 19th September 2003 05:14 AM
AC Power source Sarac Electronic Projects Design/Ideas/Reviews 12 18th July 2003 05:26 PM
12v mobile small power source lazynok Electronic Projects Design/Ideas/Reviews 1 9th June 2003 08:05 PM
