Old 17th April 2008, 02:53 PM   (permalink)
Default Upper Cut off Frequency in Common Emitter Amplifier
Hi
Im designing an common emitter amplifier and I have the following specification.
Frequency response:
Lower cut-off frequency: 40 Hz
Upper cut-off frequency: 1 MHz
I have worked out a suitable value for a coupling capacitor to give me that lower cut off but I have never covered how to implement an upper cut off frequency before?
I would know how to calculate the desired value fine but where in a common emitter amplifier would you place a capacitor to give you an upper cut off frequency?
Sorry if this isnt the right place fot this question, I know its a bit basic but im totally stuck.
Thanks for any help.
Callo1234 is offline
Old 17th April 2008, 03:20 PM   (permalink)
Do you have a SPICE program where you can simulate the amplifier on you computer?
Connect a capacitor from collector to ground. Adding capacitive loading will slow down the transistor.
Connect a capacitor across the collector resistor. Same effect.
Connect a capacitor from C to B. “Miller” capacitor will slow down the amplifier.
I believe your emitter is at ground. Break open the E to ground connection. Add an inductor. At low frequencies (below 1mhz) the inductor will look like a short. At high frequencies (above 1mhz) the inductor will add emitter resistance. The gain is the ratio of R-Collector and R-Emitter.
If you are really desperate, add RC low pass filter to the base.
I know, too many options!
ronsimpson is offline
Old 17th April 2008, 03:29 PM   (permalink)
by upper cuttoff frequency thats gonna be an LPF (series resistor then cap going to ground) You can add this on the output/collector. Guessing you can do the calculations for that already.
stickpin is offline
Old 18th April 2008, 01:38 PM   (permalink)
Thanks for your help guys,
Ive had to split my emitter resistor into 2 (bypassing one of them with my parallel capacitor to ground at my cut off frequency), to give me the midband gain i require and I think my circuit is sorted now.
One really stupid question though, this is my first ever circuit and i have never used multisim but i have to test to see if my characteristics of the circuit meet the spec in my textbook.
How would i measure to see if my gain and frequency responses work, i think i need to use the bode plotter but im not sure how i would connect it up?
Sorry for the newbie question but this work is a year ahead of where I am at (ive just started my course but i think i get the basics well.)
Old 18th April 2008, 05:13 PM   (permalink)
you could use a signal generator to your amplifier i/p. vary the frequency while using an oscilloscope to measure the o/p. When you just exceed the upper cut-off, your o/p should measure zero or nearly so. Likewise for the lower cut-off.
Hope this helps
Everybody can but not everybody will.
aibelectronics is offline
Variable capacitor circuits walters General Electronics Chat 83 11th March 2008 03:59 PM
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 03:44 PM
sample frequency and upper limit Gaston General Electronics Chat 20 10th June 2007 10:22 PM
Optimal quench frequency mstechca General Electronics Chat 1 1st July 2005 06:13 AM
transistor amplifier frequency mstechca Electronic Projects Design/Ideas/Reviews 1 9th June 2003 08:48 PM
