| Hello, I am currently in college and working on a final project. It is a 5-channel color organ made up of 5 active filters (opamp sallen-key filters to specify). This may seem like a stupid question but if these filters are of unity gain, do the opamps need a DC supply voltage? If so, how do I determine the DC supply voltage to use? Thanks in advance | |
| The supply voltage needs to be greater than the signal P-P. Most amplifiers cannot pull their outputs to the + and – supply pins. If your signal is 5 volts pk or 10 volts p-p then the amplifier needs 3 volts head room so you need +8 volts and –8 volts minimum. If your signal is AC coupled and is centered around ½ supply then you need 16 volts of supply. Do op-amplifiers (with a gain of 1) need a supply voltage? Does your car need a motor to go on a flat road? Gain of 2 = uphill. Gain of 0.5 = down hill. (keep the motor running) | |
| Passive & active filters | maidmarion | General Electronics Chat | 3 | 9th March 2008 03:34 AM |
| What are the uses for fourth order active filters? | alexander3133 | General Electronics Chat | 8 | 16th October 2007 04:57 PM |
| Active High and Active Low | Badar | General Electronics Chat | 4 | 28th August 2007 02:05 AM |
| Active filters/ tone controls | Amagic | General Electronics Chat | 0 | 18th July 2007 12:15 AM |
| Help with active filters | RiPz | Electronic Projects Design/Ideas/Reviews | 2 | 18th December 2004 01:17 AM |
