Old 18th April 2008, 11:40 AM   (permalink)
Originally Posted by ptr25
Yeh thats what i thought, the site you suggested was quite helpful, i think i might just opt for a dedicated charging ic. thanks.
A good quality charger should last a long time.
As you know, even with careful charge/discharge a rechargeable battery has a limited life and you have to buy replacements in the future.
Rechargeable batteries are not cheap, so its a good long term financial investment to make a charger that will give you the longest battery life.
I would be interested to see your final design.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 18th April 2008, 02:52 PM   (permalink)
I think you should research the voltage that is required to fully charge a lithium battery because 4.0V is too low.
Also you should see the max allowed charging current spec'd for your battery so it doesn't catch on fire or explode.
Research lithium chargers in general so you can see that the charging must be shut off when the battery reduces its own charging current to a certain low current.
Or use a battery charger IC made for charging a lithium battery.
audioguru is offline
Solar Battery Charger (you knew it would happen :D) Krumlink Electronic Projects Design/Ideas/Reviews 21 17th October 2007 10:41 PM
Solar Battery Charger suggestions Needed... iONic Electronic Projects Design/Ideas/Reviews 10 3rd September 2007 10:07 PM
Solar Powered Charger vinnie_c Electronic Projects Design/Ideas/Reviews 3 16th June 2007 02:05 AM
Solar Powered Battery Charger tydude Electronic Projects Design/Ideas/Reviews 7 18th March 2007 11:32 AM
Solar battery charger with moving panel Hanford Electronic Projects Design/Ideas/Reviews 6 8th October 2006 02:38 PM
