| have a question about the LDO chip TLE4266G. What we need is to transfer 12V to 5V , I read the datasheet of the chip , and find out the Figure3 on page7 . Here is the question : There are two capacitors before the input pin of , one is 470uF , the other is 100nF . I know that the larger capacitor is to filter the low Frequency Noise and the lower capacitor is to filter the High Frequency Noise . 1. What if I change the 470uF to 100uF ? What kind of effect it will be ? 2. The 100nF should be ceramic kind . What about the 470uF ? Should it be aluminium electrolytical or tantalum electrolytical or other material? (Our space is very limited , especially the height of the capacitor , I know aluminium electrolytical capacitor is very large.) Thank you. Your reply is highly appreciated. | |
The 7805 still needs capacitors on its input and oulput, but their values are less critical than with the LDO ones.
__________________ E Cerfoglio Buenos Aires Argentina | ||
| If your input voltage is rectified AC and you change the input side capacitor from 470uF to 100uF, your ripple voltage will go up by a factor of about 5, regardless of what type of regulator you use. Will your circuit still work under this condition? | |
| My 12V is from the accumulator . I am sorry that is not the original design of mine. I think it's not wise to use a LDO to transfer 12V to 5V . It's better to use a DC/DC converter to do that , is that right ? But the price of the DC/DC is higher , and this is also a balance from PRICE to Function . I find the price from the manual of premierelectronics , and find out that : when the quantity is 100+,the normal aluminium electrolytical is 0.07$, but the tantalum is 0.7$!!! It's so expensive that exceed my imagination. | |
| Can i have the Documents for Basic Capacitor and Inductor theory | |
| | (permalink) | |||
Both are linear regulators, but the LDO is a special one that works well with a low voltage difference between input and output. With a 7 V difference you don't need to use an LDO. If there are no long wires to pick up noise, a 7805 fed from a battery should work OK with small capacitors at its input and output - no need to use tantalum ones. Deppending on the load, you may use only a pair of 100 nf (= .1µF) ceramic capacitors, one at the 7805's input and another at its output. Quote:
__________________ E Cerfoglio Buenos Aires Argentina | ||||
| Thank you a lot ,my fellows . The accumulator means accumulator battery which used in the car. And question about 7805 which ecerfoglio mentioned : 7805 and LDO are both linear regulator , if they have the same input voltage and the same output voltage , what difference should it be between them ? It's just that the LDO is more suitable for the Low-Dropout situation? | |
| Difference is 7805 is cheaper, I'd say. | |
| | (permalink) | ||
But if you have only a little difference between input and output (about 3 V or less) the 7805 stops working and the only option is a LDO regulator (or else a switching supply, like a DC/DC converter).
| Like said above, some LDO regulators have stability problems with certain values of output capacitors, and they are usually more expensive than cheap 7805 type regulators. If you already have the LDO you can use them, but if not I would buy the 7805 type. | |
| Thank you all a lot ! | |
| Digital to analog converter chip | vuchris | Electronic Projects Design/Ideas/Reviews | 6 | 16th October 2007 10:02 AM |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Help me choose PWM chip! | Oznog | General Electronics Chat | 2 | 9th March 2005 10:15 AM |
| Answers for cisco test | faiz | General Electronics Chat | 0 | 13th July 2004 04:06 PM |
| Current or power limits for capacitors | stevez | General Electronics Chat | 4 | 21st May 2003 12:08 PM |
