Old 13th April 2008, 02:12 AM   (permalink)
Default Air Coil Inductance
I have noticed there are different Inductance formula's for a various types of air coils & there design, single layer spiral, flat wound spiral, multilayer etc.
My question is for the design of Jumble wound air coils:
What is the Inductance formula for a Jumble wound---Random wound air coil & the necessary dimension points needed to be taken for the caculation.
Some say you use the single layer spiral air coil formula, others say use the multilayer formula & some say neither apply?
Is there a site that i can go to to look this up or can anybody help me out?
Thank You
codan is offline
Old 13th April 2008, 07:39 AM   (permalink)
My father's old engineering handbooks state that the formula for a multilayer coil is only approximate, being most accurate where the cross sectional area is close to being a square (10:9) and the proportional diameter is close to the illustrated drawing. I suppose the formula for a single layer coil is also a close approximation.
{EDIT} Multilayer coil formula used is L=(0.8a^2N^2)/(6a+9b+10c) where L is microhenries, (a) is mean radius, (b) is length and (c) is winding thickness in inches. I entered the dimensions into a spreadsheet years ago and found the optimum dimensions for creating the most inductance from a given length of wire using this formula, but I can't post the results with 100% confidence that I remember them correctly. I suspect the ratio was also 6:10:9.{/EDIT}
The REAL formulas I saw in the book are infinitely long and contain undecipherable math.
I would think that if the coil is flat, use the single layer formula. If the cross sectional area is close to square, use the multilayer formula. If it is neither, use the technique used by design engineers in the 1930s: experiment with prototypes until it works.
Bob Scott is offline
Old 13th April 2008, 12:47 PM   (permalink)
What inductance do you require?
If it's under 1µH or so a single layer coil is probably the best way to go.
Another question is, why not buy it? This is probably the most sensible option for inductances over a few µH.
Screen name: Aloone_Jonez
Hero999 is offline
Old 13th April 2008, 01:42 PM   (permalink)
Thank You
I have some calculators here that I have created:
http://www3.telus.net/chemelec/Calcu...alculators.htm
But the Problem with Scramble wound is How Loose or How Tight is it Wound.
Sorry, You can't get an Accurate Formula because of this.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 14th April 2008, 01:06 PM   (permalink)
I recall seeing a chapter in an amateur radio reference - ARRL Handbook for Radio Amateurs - that included the various theoretical formulas as well as some suggested adjustment factors that might help to account for the difference between theory and actual result. Those were for the simpler coils but might be of some help. As already suggested, scramble wound has so many variables that it might be impossible to accurately predict the end result.
If I had this to do, I would do some experiments to compare a multilayer prediction to random wind - to see what direction the inductance takes. I would think that the relative density of turns would be less for random wind.
stevez
stevez is offline
Old 15th April 2008, 06:40 AM   (permalink)
Many thanks for the replies, it has been helpful.
Thank You Again.
codan is offline
Simple Coil Gun Someone Electro Electronic Projects 62 8th May 2007 01:41 PM
Tesla Coil + PIC Microcontroller jrz126 General Electronics Chat 17 9th April 2007 01:21 PM
resonant coils question evandude General Electronics Chat 3 12th April 2006 08:17 PM
relay coil inductance? danielsmusic Chit-Chat 16 2nd October 2005 04:03 PM
How do u measure the inductance of an air coil? QuickStrike General Electronics Chat 3 31st May 2005 01:26 PM
