+ Reply to Thread
Results 1 to 9 of 9
Thread: Max Voltage of Ceramic Capacitor
  1. #1
    Peter_wadley Good Peter_wadley Good
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    Default Max Voltage of Ceramic Capacitor
    I cant seem to find out what the max Voltage you can apply to this capacitor is:
    "Stick around" - Arnold Schwarzenegger in The Predator after impaling a soldier to a wood post
    9vDC Guitar Pedal PSU
    PIC16F84a Game Module
  2. #2
    crust Okay
    Join Date
    Sep 2003
    Posts
    728
    There is a glare on the part, but I believe I see an E, that means 25V assuming this part follows the general marking standard
  3. #3
    Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent Krumlink Excellent
    Join Date
    Aug 2007
    Location
    Michigan, USA
    Posts
    2,093
    Blog Entries
    1
    E5M it reads.
    IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
  4. #4
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    Quote Originally Posted by crust
    OK thanks!
    Do you by chance have a link to the marking standards?
  5. #5
    crust Okay
    Join Date
    Sep 2003
    Posts
    728
    They are in a book I have, but a quick search yielded this. I didn't check it so I can't attest to its correctness.
  6. #6
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    Yes thats the same one I found... its perfect
    I was always under the impression ceramic caps could withstand a number of KV, thank good i asked!!
  7. #7
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,149
    Most ceramic capacitors can only stand from 25V to 100V but some are only rated to 16V.
    if I know the answer.
  8. #8
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    In the olden days, the ceramic caps that were used in tube circuits had to withstand several hundred volts. And some high power transmitter circuits run on well over a thousand volts. Thus the typical ceramic cap was designed to withstand high voltages. Now there's not much need for such high voltages so the caps are correspondingly lower voltage since a lower voltage cap can use a thinner insulator between conducting layers, making the cap physically smaller.
  9. #9
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,793
    Quote Originally Posted by Peter_wadley
    It's usually the blue circular ones that are high voltage, they commonly go faulty in TV's - easy to spot though, they either have an obvious burnt spot on them, or a burnt split.
+ Reply to Thread
  1. Voltage
    By ElectroMaster in forum Electronic Theory
    Latest: 8th August 2007, 05:35 PM
  2. Voltage Clamp
    By ThirtyTwo in forum General Electronics Chat
    Latest: 11th August 2006, 04:05 PM
  3. Filtering capacitor is increasing the voltage, ideas needed
    By Neil E. in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th June 2006, 09:39 AM
  4. LED Project... Is the diagram correct?
    By Maxer in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th December 2004, 03:18 PM
  5. Why use 2 capacitor at output of voltage regulator?
    By StupidDum in forum General Electronics Chat
    Latest: 27th October 2004, 03:11 AM
Tags for this Thread
