Old 14th April 2008, 05:07 AM   (permalink)
Default VIAs
Originally Posted by petrv
What about defining the prototype area as an Eagle component (in a library) ?
Just create a package with a lot of pads (looking a bit like a PGA) - then you can easily place it on any board layout you need. And it won't disappear when ripping up traces.
Petr
A very good idea! Don't forget to create a symbol as well. That way you can create a device which can be used in any circuit where it is necessary.
I doubt that the posted example of 3v0 has a schematic. All parts look pretty much like a sole PCB. For a PCB there is no ERC, just a DRC, and that's where it might get confusing not to know exactly which parts are connected. No cross-check is possible.
Creating a package with a certain amount of "vias" isn't flexible enough, e.g. it contains 50, but all of a sudden your application requires more than those. There is no other way than copying and pasting and make a new package. Editing the existing one is impossible. You'll be confronted with the message: "package in use".
Using my method of creating a device with just one "via" you are free to add or erase any one. If erased in the schematic they will also be erased on the PCB because of a valid forward- backward annotation with the schematic and the board loaded.
There is another disadvantage to just adding "vias" which in reality are pads. Only the maker can read that schematic and PCB.
Hans
Boncuk is offline
Old 14th April 2008, 10:38 AM   (permalink)
Hans
You can not tell if I used a schematic by looking at the board. I would not create a board without a schematic. I am a firm beliver in ERC and DRC.
3v0 is offline
Eagle Issue w/Transistor amdkicksass Electronic Projects Design/Ideas/Reviews 9 29th August 2007 01:04 AM
How to properly do PCB edge connections in Eagle? toodles Electronic Projects Design/Ideas/Reviews 2 10th April 2007 11:36 PM
Eagle import/export -> Protel SE midnitrcr Electronic Projects Design/Ideas/Reviews 0 10th November 2006 09:54 PM
Microchip library for eagle nclark Micro Controllers 2 14th November 2005 08:12 PM
smd's in Eagle justDIY Electronic Projects Design/Ideas/Reviews 1 31st July 2005 09:22 PM
