+ Reply to Thread
Results 1 to 9 of 9
Thread: switches SPST like DPDT?
  1. #1
    Norlin Good Norlin Good Norlin Good
    Join Date
    May 2007
    Location
    Lawrenceville, NJ
    Posts
    148
    Default switches SPST like DPDT?
    I have a problem where I want to have 6 switches controlling four lines. Each switch drives two lines high, each seperate switch drives a different combination of two lines. So if I have four lines labelled A through D, each switch would do the following:
    1 AB
    2 AC
    3 AD
    4 BC
    5 BD
    6 CD
    The problem comes that if you wire the switches up like this, all four lines will be connected together. You could overcome this with a double pole double throw switch (or is there another switch that has one common line on one side and two on the other?) you'd tie the two poles on one side of the switch to your voltage source and each of the other two poles to one line each.
    eg:
    Vcc --- SWITCH --- A
    Vcc --- SWITCH --- B
    However, I haven't been able to find tiny DPDT switches, so I have a bunch of SPST switches which are of perfect size. The only way I know how to solve this problem is to use a bunch of diodes, so I'd have
    Vcc --- SWITCH --- diode to A
                   --- diode to B
    This solution would work for me, but I'd end up with 12 diodes and I'm trying to keep the size (and complexity) of the circuit to a minimum as it's to be a keyfob sized transmitter...can anyone think of another way to implement this with SPST switches? If I were to have to use a 12pin or larger IC, I might as well use the diodes as they'd be around the same size.
  2. #2
    HS3
    HS3 is offline
    HS3 Okay
    Join Date
    Apr 2008
    Posts
    41
    With individual switches what happens if two are ON at the same time? It seems to me this requires a 6 position rotary switch or a set of push-switches where pusing one releses the others.
  3. #3
    jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    If you resign yourself that you will need a chip, a simple microcontroller would be easy. John
  4. #4
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,013
    The simplest standard logic circuit I could think of to work with SPDT switches uses 4 triple-input OR gates. But that would require 2 chips since I think the most available on one chip is 3 gates.
  5. #5
    john1 Good john1 Good
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    Yes, using simple spst switches, i think 12 diodes
    is the minimum you would need to do this.
    John
  6. #6
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    however some of the small DIL switches, (like a chip) are spdt switches,
    and if you can use those then you can do it using four switches and
    two diodes.
    If you can spare the room, you could use six of the switches and replace
    the diodes ive drawn with another two switches, but i think the diodes
    are actually smaller than the switches, so ive left the drawing as four
    switches and two diodes.
    I've drawn the same circuit six times, cos that is easier than trying
    to look at one drawing, in six different states.
    John
  7. #7
    Join Date
    May 2007
    Location
    Lawrenceville, NJ
    Posts
    148
    Ah wow, I like that solution john1, I went ahead and made a PCB for the prototype (which will probably end up being the production model as I'm only planning on making one unless is breaks) using 12 diodes, but I'll keep your drawing in mind if I make it again (or anything similar in the future). I know I have a few SPDT switches that I salvaged, I think they came from computer mouses (mice?). Most of my tiny switches are SPST though.
  8. #8
    Join Date
    May 2007
    Location
    Lawrenceville, NJ
    Posts
    148
    Ooops, looking at the drawing again I see that multiple switches might have to be simultaneously pushed to get the outputs, in which case singly wiring each switch to an output would have the same results. Am looking to press a single button to get the desired output.
  9. #9
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    Hi Norlin,
    Thank you for your very positive reply,
    and i am sorry i did not spot that you wanted to press a single button to do it.
    Yes, more than one switch would have to be operated using that arrangement.
    I was very tired when i posted that circuit, and opon looking at it again, i now
    see that the diodes i included could just as easily be wires, with the same result.
    So it would just be the switches, no diodes.
    However, if you want six different buttons to press, for the six different outputs,
    then i dont think you can get the components down below twelve diodes.
    Unless the current demands are quite small, then maybe six transistors could be
    used as 'diode-pairs' instead of 12 diodes.
    It might be possible to incorporate a tiny slide-switch, (spdt) just to halve the
    number of buttons, so you would move the slide switch, then press one of three buttons
    but i haven't looked at the circuit possibilities, although i know that some very
    small slide switches are used here and there, but i don't know how much room you
    have to play with.
    Or if moving a small preset slide switch before pressing the button
    is a practical option for your purpose.
    John
+ Reply to Thread
  1. Questions about SPST switch wiring
    By Eyedoc in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th January 2008, 04:13 PM
  2. Good Electronic Supply's Sites, Everyone Come On In! :P
    By Electric Rain in forum General Electronics Chat
    Latest: 27th August 2007, 11:06 PM
  3. 6 momentary switches 6 LEDs
    By Digger7 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd February 2007, 12:16 PM
  4. PIC Switch Management Techniques
    By Mike, K8LH in forum Micro Controllers
    Latest: 28th September 2006, 12:33 PM
  5. Best online ordering for a reed relay and dpdt toggle switch
    By Stimulation in forum General Electronics Chat
    Latest: 10th July 2003, 04:40 PM
Tags for this Thread
