If you want to read up on OBD2, then http://www.obd2crazy.com/ is a good place to start and find out what it can do and what is available. Torben | ||
| Thanks Torben, No this is not for a specific car per/se. Although I would use it for my car, I wouldn't like it to be for my car only. What if I change cars? What if I have an old car and a new car (which I do)? Then I wouldn't be able to use something that only functions with an ODBC port. In short, I think it would be best to view this from the perspective of an automotive shop application. I would want to test just about every electrical component of a car (AC and DC) with, I would imagine, a pretty high range of voltage. What would you think, up to about 100 volts? Can this be done? Is this possible? Am I asking too much? | |
Without you having to run wires all over your car to all the different bits you want to test, then back to a central connector (essentially building in your own pseudo-ODB2 system), I'd say your best bet might be just to get your hands on a decent automotive voltmeter. Googling "fluke automotive meters" or such might lead you to some ideas. However, I suspect that those things might be slightly more than you wanted to pay, but as far as I know most folks who've shelled out for a Fluke meter have been happy customers for years after. You won't get an oscilloscope-type readout (but you can get handheld scopes too, if you want) but you'll be able to read any voltage or amperage in your car if you can reach it. Is that something like what you had in mind? Otherwise I'm not sure what to suggest. Torben | ||
what do you mean it's not freeware? it's FREE for U! input frequecy?! it's not a TEKTRONIX oscilloscope.. please check the site again.. | ||
| Just a quick warning for those who wants to play with PC oscilloscopes.... of course It's nowhere as good as TEKTRONIX oscilloscopes I once found a DOS program which provides a parallel port oscilloscope via a 5V ADC. I mistakenly supplied 15V to it - surprisingly the ADC was not damaged but the parralel port was! Luckily I did not use the built-in port, I use an ISA card for parallel port so replacing it was easy. When the card was taken out, I noticed several chips were severely burned... At another time I used a sound-card oscilloscope (input via microphone). I was designing FM transmitter so without thinking about the supported recording frequency of a sound card (max. 44.1kHz), I attempted to see the waveform from the output of the RF oscillator. The computer immediately restarted, and after that I found my sound card to be "deaf" - playback was still ok but recording could not work. Probably the too high frequency from the oscillator had killed the microphone part of the sound card? I always use proper oscilloscope for experiments. To me, PC oscilloscope only works as proof-of-concept. Last edited by mdanh2002; 17th April 2008 at 07:38 AM. | |
| | (permalink) | ||||
All in all I have no reasons to think this other program is as good--speaking purely within the limitations of the soundcard scope realm, as we are. Torben Last edited by Torben; 17th April 2008 at 08:04 AM. | |||||
What was the voltage on the HF signal you fed the thing? Torben | ||
In my experience audio coming from most headphone output is seldom above 3V. Not sure how high the sound card can "suffer". | ||
Torben | ||
| Torben we know each other long time from another forum... up to now we never had something to debate and i want to keep it that way. although you don't help much... if you like the program you use then it's fine with me...i just gave an alternative choice...and i did't mean to present my link better than yours (sorry if i did and i didn't noticed it.) but some of your coments you did i think they are wrong! and you keep on this motive insisting. the program is not freeware but it's free for you to use it... are you going to use it commercially and you mind that so much?! you said that your soundcard has 8 channels... are you sure you want so many channels from a software oscilloscope? nice function if exists...but not even the real oscilloscopes have 8 usualy i think they are 2 or 4 but that's fine for most of us. about the 96KHz you reffered to... i think that's your soundcard's sampling rate! and not the audio frequency it can accept. again...i'll say i mean no offence to you...but you do make me respond because i think some things you say are kinda wrong. Last edited by whiz115; 18th April 2008 at 07:25 PM. | |
| | (permalink) | |||||
Torben | ||||||
| no prob man! everything is fine! | |
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 02:45 PM |
| Recommend a Good Older Oscilloscope | bryan | Micro Controllers | 4 | 13th January 2008 01:37 AM |
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
| Layout program : anything free to recommend | winterhunter | General Electronics Chat | 6 | 1st March 2007 04:01 PM |
| PicBasic Keypad program | Sora | Micro Controllers | 0 | 20th April 2004 08:02 PM |
