I want to control a variable resistor externally. I was wondering if this was possible. I was going to have labVIEW software that controlled via the output of the daq a variable resistor. So I was wondering if it was possible to externally control. Any ideas would be awesome. Jeff | |
Look up digital potentiometers. John
| | #3 | |
You need to be more specific. Variable resistor? For what ranges of voltages, currents, etc? What application? It may well be there are ready-made components you can use or you may need to design your own solution. | ||
Biologically implementing a single cell model. I was going to have the resistors controlled by the output of a DAQ. I could change range of voltages. I was going to use 0 to 1 volt. The computer is going to control the differential equations. I was going to have the DAQ output a voltage corresponding that I wanted to control the resistance to model the voltage across the membrane. I will probably have to tweak the output of the DAQ. Let me know if you have any tips.
Seems like you could eliminate the DAQ and just use a digital potentiometer. What is the resistance range you need?
| | #6 |
It has to be externally controlled. Resistance range is yet to be determined. I want it to model the spiking of a cell so not sure. It depends on all other resistances. I would say 20-500. I am not sure yet. It can't be controlled by hand.
| | #7 |
Analog Devices sells numerous digitally controlled resistors. For example, the AD5254 has 256 steps (8-bits) and is available in a 1K ohm version. If that resolution is adequate, it might do what you want.
| controlled, current, resistor, variable, voltage |
| Current source | GagoX | Electronic Projects Design/Ideas/Reviews | 13 | 12th January 2008 07:32 PM |
| Read current (voltage drop across resistor) in two directions | Odysseas | Micro Controllers | 22 | 18th October 2007 05:24 AM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 01:50 PM |
| 1 LM317 to regulate both voltage and current , down to 0V | dso310 | Electronic Projects Design/Ideas/Reviews | 7 | 2nd June 2005 04:53 PM |
