| Experienced Member | Somebody told me that capacitors with leakage tend to give higher reading than their actual capacitance, is that true? thanks! |
| Experienced Member | Try to connect a high value resistor across (creating leakage deliberately)and see you would have first hand knowledge.
__________________ Regards, Sarma. |
| Super Moderator | Quote:
| Experienced Member | Some multimeter measure the impedance of the capacitor at a certain frequency. The lower the impedance the larger the capaciticance. Therefore, if the capacitor is leaky, the impedance will be lower than expected which will give a correspondingly high reading. |
| Experienced Member | Quote:
herro999 there are other methods other than measuring the impedance?! | |
| Super Moderator | I've just bought one of these at work http://www.peakelec.co.uk/acatalog/jz_esr60.html Measuring capacitance isn't much use, it's ESR you need to test, and this does both. A great little device, and PIC based as well |
That is a neat instrument there but a bit too expensive for amateurs and students. I have built myself a very simple ESR meter which is good enough for everyday testing in that it gives you a rough idea. When repairing power supplies (the electrolytics tend to go like crazy) I can run a quick check with the capacitors in-circuit and this is a great first test. | |
| Experienced Member | Care to share the schematic? |
| Experienced Member | If we take that to the nth degree, the National Institute of Standards and Technology (NIST, formerly the National Bureau of Standards) should shut down their division on capacitance standards. Somewhere in the chain, SOMEONE has to measure the capacitance, whether it's the QC department of the cap manufacturer or their design division. One excellent excuse for testing for capacitance that I do is sorting caps for the range capacitors on a function, pulse or signal generator. They are sorted according to the significant digits of the value for each decade. You install caps that have the same significant digits regardless of their actual value. That way, the single frequency-calibration adjustment will be good for all ranges and not just the one range that's used for the adjustment. If you're using an analog dial (or better yet, restoring an older generator), the overall accuracy of the instrument is improved by a full magnitude that way. Yes, you can use a counter to measure the output frequency in actual use, but for many applications (alignment of an antique radio comes to mind), you don't need counter accuracy but would be content with better than off-the-design-shelf accuracy for an older instrument. Dean
__________________ Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. |
| | (permalink) | ||
But notice that in either of those two cases, measuring the capacitance doesn't tell if the capacitor is any good or not - although during manufacture they test ESR as well anyway (which is where the ESR spec for the capacitor comes from). | ||
| | (permalink) | ||
ESR has become more of an issue in recent years for two main reasons. One is that old electrolytics were huge by today's standards and had lower ESR. Miniaturization has brought higher ESR and new technologies to lower it are needed. Another is that old power supplies worked at very low frequency and with very low ripple current per capacitance unit. SMPS have brought a huge increase in current per microfarad and this requires lowering the ESR to a minimum. Cheap capacitors with higher ESR may not be suitable for certain applications like high frequency SMPS but they can be perfectly good for other uses and I need to know the capacitance. I would still say that in the beginner's toolbox it makes more sense to have a capacitance meter than an ESR meter and capcitance meters are cheaper and more plentiful anyway. Note also that capacitance value depends on several factors like bias voltage so it is not like it is a fixed, immutable value. A capacitor which is nominally 1 uF at 200 V will have a very different capacity at 10 V. Also, for the purpose of repair and general maintenance, the technician does not really need to measure ESR with much precission because just an order of magnitude is enough. As I say, I have a very basic instrument and I have learnt to tell good from bad capacitors pretty quick even though I have no idea of numerical value of ESR. Basically 95% of caps fall into two main categories (a) Needle hardly moves (high ESR) so cap is bad or (2) needle goes to end of scale (low ESR) so cap is good. It is rare that I get a middle of scale reading and then I need to take a closer look. If cap is of very low capacitance then it might be passable, otherwise I discard it. Also, it depends on use. If it will go in a high frequency SMPS then I want to see the needle go to the end of the scale but if it will go in some low-current application then it may be perfectly good. The thing about ESR is that once a cap begins to go bad the use will make it quickly spiral and ESR shoots through the roof. I have repaired many SMPS which were bad due to bad caps. Generally I will replace them all because if a bad brand was used then I want to replace them before they fail again. For normal repair work you do not need a precission ESR meter. A basic instrument which gives a general idea is enough. Quote:
| | (permalink) | ||
What does change massively is ESR (sorry to mention it again), high voltage capacitors generally have really rubbish ESR values. Quote:
| Experienced Member | Some people think that replacing a capacitor with another one of the same capacitance but rated for higher voltage and higher temperature is always a good thing and that it will last longer. But higher rated voltage and higher rated temperature nearly always mean higher ESR which leads to higher temperature and shorter life. What is generally true is that it is good if you replace a capacitor with another one of higher capacitance because this means lower ESR. Within limits and space constraints I generally replace SMPS caps with somewhat larger values. And if space permits I will install two caps in parallel rather than just one. This also lowers ESR. I have read (but not precisely confirmed personally) that caps rated for higher voltages will not keep their capacitance value if continuously biased at much lower voltages because the higher voltage determines the thickness of the oxide dielectric. The idea is that the dielectric degrades over time and needs the voltage to keep in in condition. Quote:
| Experienced Member | HS3 from what i understand nigel speaks about diagnosis of a faulty cap. Quote:
if you tell me that capacitance goes always down while the caps are aging or get misused, then i think i'll forget about ESR meter, because i'm not interested for anything else other than testing if an on circuit capacitor is fine. | |
| HELP HELP!! some question related to my homework pls help~ | anzdyy | Electronic Projects Design/Ideas/Reviews | 15 | 2nd March 2008 02:08 PM |
| A whole lot of question (z80 related, along with some others) | Marks256 | General Electronics Chat | 35 | 8th February 2008 10:00 PM |
| Analog Meter | windozeuser | General Electronics Chat | 19 | 3rd October 2007 02:44 PM |
| peak program meter question | Othello | General Electronics Chat | 9 | 30th November 2006 12:30 AM |
| Panel meter, analog VS digital | Johnson777717 | General Electronics Chat | 7 | 22nd June 2004 11:33 PM |
