Old 2nd April 2008, 06:07 PM   (permalink)
Default Encoder/Decoder Uniqueness
Could any one here please explain...
I am trying to use RF600 encoder/decoder pairs.
Datasheet says that "up to seven transmitters can be learnt"
Does it mean that one decoder can respond to seven different transmitters (non-simulataneously/operating simultaneously)?
If I want to operate say 50 encoder/decoder pairs at one place, how can i be sure that the uniqueness of a particular encoder/decoder pair is maintained?
Please elaborate...
RSG is offline
Old 2nd April 2008, 07:18 PM   (permalink)
Apparently the decoder chip can learn codes from up to 7 different encoder chips stand-alone, or from up to 48 different encoders if used with an external EEPROM memory. The decoder can respond to any of the 7 (48) but not likely simultaneously since it wouldn't be able to uniquely sort out two overlapping signals.
The codes are uniquely (and randomly) determined when the decoder learns a code from the encoder. There are 4 billion changing codes (see pg.2 in data sheet) so it is unlikely that two codes would be the same for 50 encoder/decoder pairs.
crutschow is offline
Old 3rd April 2008, 08:39 PM   (permalink)
Default "Manufacturer's key"
Custom Versions of RF600E/D
"Custom versions of the RF600E / D chipset are available, programmed with a unique ‘Manufacturers Key’ which means that the transmitter and receiver will respond only to other devices with the same unique manufacturers key. This provides a bespoke remote chipset for OEM applications".
I thought that once the decoder learns a particular transmitter, then it does NOT respond to any other encoder/transmitter...then, what is this concept of specific manufacturer's key?...any idea?
RSG
RSG is offline
Old 3rd April 2008, 09:38 PM   (permalink)
It sounds like you can't program a device to accept another Manufacturers Key. Only devices with the same Manufacturers Key can be programmed to read each other.
FM encoder/decoder to switch relay atari7202 Electronic Projects Design/Ideas/Reviews 2 29th February 2008 03:21 AM
Choosing Encoder/Decoder ian8115 General Electronics Chat 1 16th March 2007 02:52 PM
which is most widely used rf encoder/decoder nikhil arora Electronic Projects Design/Ideas/Reviews 8 2nd March 2006 12:03 PM
IR ENCODER/DECODER using PIC16f84A - help need ideas vortech1 Micro Controllers 2 16th May 2004 06:43 PM
12 Channel Encoder/Decoder? Squintz General Electronics Chat 0 3rd November 2003 06:31 PM
