Old 31st March 2008, 08:16 AM   (permalink)
Default Dumb Question from noob: My 9V battery not working?
Hello there everyone,
I am a noob to the world of electronics. I recently bought a multimeter INNOVA 3310 from iEquus. An Energizer 9V battery recently died (it was being used in the personal weighing machine that I have) and I wanted to verify that the voltage was indeed not there. When used my multimeter on it, it gave me a reading of 8.38V. What exactly does this mean? Why was the weighing machine not using this battery? Because it was just a little bit below 9V? Does that mean I can use this battery elsewhere where less than 9V is required or should I just throw the battery away?
It is not about the battery, but about the general concept of non-chargeable batteries if they can be reused even if they fall below their voltage level.
I seek enlightenment Any comments will be appreciated.
Zef
zef is offline
Old 31st March 2008, 08:24 AM   (permalink)
Zef
When you measure the battery voltage directly with your meter, without any other load drawing current from the battery it will give you a higher than expected reading. [ the battery is NOT supplying any current to a load]
Place the battery back in the weigh machine and measure the battery voltage while its in the weigh machine.
This will give a 'onload' voltage.. tell us what you read.
If you have any resistors handy you could place a 100R across the battery while you measure the voltage.
Do you follow this.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 31st March 2008, 08:27 AM   (permalink)
Thnx eric. I understand and will comply as soon as I get hold of my weighing machine.
zef is offline
Old 31st March 2008, 05:11 PM   (permalink)
My smoke detectors beep when the 9V battery is low. When I measure the battery voltage of a weak one it measures 8.5V even in the smoke detector.
The circuit in the destector applies a load to the battery every few minutes but only for a moment for it to test the loaded voltage of the battery.
audioguru is offline
Old 1st April 2008, 07:48 AM   (permalink)
A healthy and new 9 Volt battery will have an open terminal voltage of around 9.5 - 9.6 Volts.
RODALCO is offline
working out the size of battery required jon_jon_phenomenon General Electronics Chat 4 21st March 2004 09:02 PM
9v pp3 battery question carlosthejackle2001 General Electronics Chat 3 14th February 2004 11:03 PM
another dumb question, but should be easy for you lot :) Gabrielle General Electronics Chat 15 11th August 2003 11:01 PM
Last question for NiMH battery charger eyevancsu Electronic Projects Design/Ideas/Reviews 8 1st May 2003 04:04 AM
Question regarding MAX713,712 battery charger controller... eyevancsu General Electronics Chat 3 23rd April 2003 10:02 PM
