Notices
Old 30th March 2008, 07:05 PM   (permalink (permalink))
Default Wouldl like to make a benctop varible power supply
I have found a nice transformer that puts out a little over 40 volts. The center tap puts out about 21 volts. The transformer is rated at something like 2.4 amps. It came out of an equipment monitor from IBM...
I would like to make a variable power supply with it. 0-30v would be sufficient. I would be fine with something around 2 amps (the more the better). Anyone have any ideas? I was going to go off on my own and design something, but i figured it would be safer to ask first...
Variable current would be nice, but it isn't mandatory.
Meters would be nice, too... (ok, i am done asking for features... )
thanks.
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 30th March 2008, 07:12 PM   (permalink (permalink))
Hero has a power supply project posted in the projects forum, and it seems very well developed:
http://www.electro-tech-online.com/e...er-supply.html
Take a look at that one, it should give you ideas.
BeeBop is offline
Old 30th March 2008, 07:20 PM   (permalink (permalink))
I was thinking something more or less like this
Hero's looks pretty good, too.
Marks256 is offline
Old 30th March 2008, 07:30 PM   (permalink (permalink))
There is a 0V to 30V/2mA to 3A regulated lab power supply project at Electronics-Lab. It doesn't meet its spec's and many of its parts operate beyond their max allowed ratings.
It is a kit.
We fixed and improved it and have a reliable version that meets its specs very well and there is a 5A version too.
audioguru is online now
Old 30th March 2008, 07:42 PM   (permalink (permalink))
Yeah, i saw the one at electronics lab... But after reading the thread about Electronics-lab, i am wondering whether or not not i should trust it...
Could i have a link to the "improved" one? The one that won't kill me, please.
This is the one i saw. http://www.electronics-lab.com/proje...003/index.html
But i just found this one, as well. http://www.electronics-lab.com/proje...032/index.html
Would my 21volts from the center tap work?
Marks256 is offline
Old 30th March 2008, 08:12 PM   (permalink (permalink))
Project #003 is the original faulty project that we fixed and improved.
The moderator didn't bother sorting troubleshooting, parts substitutions, adding meters, fixes and improvements etc. from the 153 pages in the forum. Many people posted their own pcb but the original one can be used with a couple of small changes. It uses a 30VAC/4.2A transformer.
I have never heard from anybody who made project #032 but it should be the same as in the datasheet for the LM723. Its minimum voltage is 3.0V and its max current is fixed at 2.5A but can be reduced to 1.7A for your transformer.
Your 21V center-tapped transformer can make an unregulated supply of 57.4V or 27.7V. No electronics parts distributor has an OPA445AP high voltage opamp in stock so you won't be able to make a 50V/1.7A project. You could make a 20V or 21V/1.7A project.
Old 30th March 2008, 08:29 PM   (permalink (permalink))
I think i may have a 30VAC transformer from an old printer. I don't know if it works yet or not...
Would a 2n3054 work instead of a 2n3055? I found a 3054 while i was trying to search for a 3055...
EDIT: Would it be possible to drop the ~40vac to 30vac?
Marks256 is offline
Old 30th March 2008, 09:01 PM   (permalink (permalink))
The 30V/3A power supply needs two 2N3055 transistors. 10 little 2N3054 transistors might work.
If you drop 10V at 3A then the power wasted is 30W. I have seen 25W resistors in an aluminum heatsinked case. Maybe somebody makes a 50W one.
Old 30th March 2008, 09:10 PM   (permalink (permalink))
Well then i am going to need to find some 2n3055s...
Marks256 is offline
Old 30th March 2008, 09:16 PM   (permalink (permalink))
The project uses a lot more than just two very common power transistors.
I recently made a separate thread about replacement opamps for it:
http://www.electronics-lab.com/forum...?topic=14259.0
Old 30th March 2008, 09:28 PM   (permalink (permalink))
Ok. Thanks audio. When i get a few more parts around, i will try to make something.
Marks256 is offline
Old 30th March 2008, 10:32 PM   (permalink (permalink))
thanks.
That transformer is probably rated at 2.4 amps, Using two diodes and the center tap as common negative.
Not the 40 volts at 2.4 amps.
With good filtering, you might possibly get 1.5 amps DC output.
And if your building a power supply, find one with both Voltage and Current limiting.
There is one on my website that fairly good.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 30th March 2008, 10:33 PM   (permalink (permalink))
Have you seen the supply here:
http://mondo-technology.com/
Click on bench power supply. John
jpanhalt is offline
Old 31st March 2008, 01:23 AM   (permalink (permalink))
I'd recommend building a bipolar trqacking supply similar to mine.
A 20V centre tapped trqansformer should pretty comfortably give a DC voltage of +-22VDC. The LM317 probaly isn't a good idea as the output current will drop at lower voltages so you're probably better off using a uA723 and a beefy transistor.
Screen name: Aloone_Jonez
Hero999 is offline
Old 31st March 2008, 02:08 AM   (permalink (permalink))
Hey Mark,
I'm also in the process of making a power supply. A few of the "must-have" features include the following:
Fixed voltage outputs of 5, 9, 12 and 15 Volts
Adjustable positive and negative outputs (-18__0__+18)
A cooling fan that goes on when a certain temperature is reached, and then turns off when the temp goes below a certain level.
LCD display
Here's a link for an inexpensive ($9.00) 3 1/2 LCD. I bought a few of these, and the work great.
http://www.allelectronics.com/cgi-bin/category.cgi
Good luck
Brian218 is offline
need help with power supply parts very info... rodniepr General Electronics Chat 0 6th April 2005 03:32 AM
PC Power Supply Problems brentonw2004 Electronic Projects Design/Ideas/Reviews 3 29th March 2005 11:00 AM
Using old power modem power supply mongoq General Electronics Chat 2 24th February 2005 08:05 PM
How to make PC power supply with voltage control Fachri Electronic Projects Design/Ideas/Reviews 1 9th January 2004 11:53 PM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 01:10 AM
