Old 31st March 2008, 04:20 AM   (permalink)
Originally Posted by chemelec
That transformer is probably rated at 2.4 amps, Using two diodes and the center tap as common negative.
Not the 40 volts at 2.4 amps.
With good filtering, you might possibly get 1.5 amps DC output.
And if your building a power supply, find one with both Voltage and Current limiting.
There is one on my website that fairly good.
No, the 40 volts is rated at 2.4 amps. The transformer was in a case (along with an EMF filter), and on the side it said "output: 40VAC @ 2.4A" Also, the module that the transformer provided power for required something around 2 amps.
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 31st March 2008, 07:08 AM   (permalink)
Originally Posted by Marks256
I would like to make a variable power supply with it. 0-30v would be sufficient. I would be fine with something around 2 amps (the more the better). Anyone have any ideas? I was going to go off on my own and design something, but i figured it would be safer to ask first...
Variable current would be nice, but it isn't mandatory.
Meters would be nice, too... (ok, i am done asking for features... )
thanks.
Last year I got around to building a replacement for my 20+ yr old noisy bench supply that lacked current limiting. The one I replaced it with is a hundred fold better in every respect; % of regulation, thermal stability, noise, etc. The schematic is attached. As configured, it is 0-24V (changing ratio of R20 & 21 to 4:1 will take it to 0-30V with the 6.0V reference), current limited and metered (LCD PM's); both voltage and current. If you have any questions, I'll be happy to answer them.
Edit: Marks256, I screwed up and posted an early, non-validated rev of the PS. If AudioGuru hadn't have posted a question regarding the efficacy of the design, you or perhaps others could have been led in the wrong direction. My apologies. The as-built that went to the board house is attached.
MRCecil is offline
Old 31st March 2008, 03:08 PM   (permalink)
Thanks, MRCecil.
Marks256 is offline
Old 31st March 2008, 03:37 PM   (permalink)
Hi MR Cecil,
What is the current rating of your power supply?
What is its transformer voltage and current rating?
I notice that the power transistor Q1 has a very low max base current of only about 30mA so if its gain is low then the max output current will be less than 1A.
Doesn't R4 get extremely hot when the load current is high?
audioguru is offline
Old 31st March 2008, 03:52 PM   (permalink)
Although a bit more complex, I like this Analogue power supply.
It is Based on the MC1466L IC, which was discontinued Years ago. But this is an All Transistor Equivalant of it.
http://www3.telus.net/chemelec/Proje...466/MC1466.htm
I have a Dual version of it, Each one is 0 to 8 amps and 0 to 36 volts. And I can Series for a slit supply or parallel them for Higher current.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 2nd April 2008, 07:16 AM   (permalink)
Originally Posted by audioguru
Hi MR Cecil,
Hi back at ya AudioGuru,
I posted the wrong schematic without checking properly; a lack of due diligence. I have edited my original post to Marks256 with the as-built. However, even it is not corrected as built. I added a 3PDT toggle sw. during assembly to change range and DP on the Vo DPM's (3.5 digit) for the 20-24V supply range. Onward to your questions...
The xformers are rated at 24V & 2.4A for the desired 2A output. R4 doesn't get too warm at all with only about 160mw worst case to dissipate (see as-built schematic). Its main function is to relieve Q2 of some of the power burden. If I had a variety of TO-92NL packaged numbers on hand R4 would have been eliminated altogether; trade offs are a fact of life. But I don't stock JIL spec semi's, and a $0.06 resistor and $0.04 xistor are cheaper than a $1.50-$2.00 Japanese xistor.
Regarding the DC current gain of the pass xistor, that would have been a major consideration in 1970 when process control, process tools, material and gas purity, Fab environment induced defects, wafer quality, etc. in virtually all Fabs regardless of manufacturer were far below today's standards. Personally, I haven't seen current gains in the 20's and 30's for the 2955 or its 3055 compliment for a very long time...perhaps I have just been fortunate though.
Merv
MRCecil is offline
Old 2nd April 2008, 10:08 PM   (permalink)
No prob. Thanks for the fix.
Marks256 is offline
need help with power supply parts very info... rodniepr General Electronics Chat 0 6th April 2005 04:33 AM
PC Power Supply Problems brentonw2004 Electronic Projects Design/Ideas/Reviews 3 29th March 2005 12:01 PM
Using old power modem power supply mongoq General Electronics Chat 2 24th February 2005 09:05 PM
How to make PC power supply with voltage control Fachri Electronic Projects Design/Ideas/Reviews 1 10th January 2004 12:54 AM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 02:10 AM
