Old 27th March 2008, 10:46 PM   (permalink)
Default Quick and Easy PCB
Is there a product out there that makes it easy to place your surface mount components on a PCB? I find it difficult to solder all my components to the board. Are there solutions where I can maybe snap in components rather than trying to solder components that are smaller than the tip of my soldering iron. A lot of the parts I get for free are surface mount components that are designed for manufacturing and not home-made PCBs.
cvrider is offline
Old 27th March 2008, 11:07 PM   (permalink)
What's wrong with a pair of fine tweezers?
I prefer most SMT parts to through hole as I don't have to drill any holes and they take up one tenth of the space.
Screen name: Aloone_Jonez
Hero999 is offline
Old 27th March 2008, 11:11 PM   (permalink)
I have heard that using silicon to stick the smd to the board before soldering make things a lot easier
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 28th March 2008, 01:09 AM   (permalink)
Default Super Glue?
I used Super Glue (the type that bonds instantly) in my first and only attempt, it worked pretty good.
Paid $1.00 in a Dollar store for a packet of three tubes.
Rolf is offline
Old 28th March 2008, 09:47 AM   (permalink)
I agree, I never use hard sticking super glue, If I need to replace or upgrade them occasionally that will be very hard So I use silicon instead.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 28th March 2008, 02:01 PM   (permalink)
Exclamation Be carefull!!
Be shure to work in a well ventilated area.
When the Super Glue (Cianoacrilate) heats up it releases some nasty chemicals.
Perhaps if you glue up the chip's body to the board it doesn't get hot enough, but if there is some glue over a copper trace...
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is offline
Old 29th March 2008, 11:40 AM   (permalink)
I've used cyanoacrylic (CA, superglue) quite a bit. The trick is to get a small dot of the stuff. For that, I put a drop of the CA on an old piece of copper PCB. Medium viscosity works well. The copper surface doesn't set the glue off, so it stays liquid. Then I use a piece of wire (1.2 to 1.5 mm dia.) to transfer a dab of the CA to where I need the component.
CA is depolymerized by relatively low heat. I have never had a problem in removal as the heat lossens it. Of course, I have only used it for 805 and 1206 resistors and caps, nothing so big that it doesn't get hot. You can buy commercial formulations for the same purpose, but the ones I have found were only sold in large quantity.
John
jpanhalt is offline
Hello Everyone, a quick ? tdexxx General Electronics Chat 5 16th December 2007 11:46 PM
Need a quick circuit for a reversing linear actuator switch... um.. QUICK iso9001 General Electronics Chat 5 28th October 2006 06:38 AM
Quick question, should be easy to answer... Electric Rain Electronic Projects Design/Ideas/Reviews 7 5th August 2004 03:28 AM
Another quick math question Eclipsed Micro Controllers 0 27th July 2004 05:13 AM
