| Hello everybody! I have DELL Latitude C600/C500 Laptop. I opened its monitor for some reason but when i reassembled it and turned it on, its LCD display was damaged. The problem with the display is that every 2nd pixel on each line is off. and the display is blur. Can anybody know what happened to it and how to fix it. Thanks | |
| Why did you disassemble it? It sounds like you've damaged the electrode strip that connects the display decoder ICs to the LED. You could try opening it up again and applying firm pressure to the where the flexible plastic PCB connects to the pannel.
| [quote=dimper129] "I opened its monitor for some reason" Just curious ? What ever you do don't damage anymore in the process the ribbon is easy to peel back if it is a pressure push in style. Listen to " Hero999 " the pressure will tell you if you have a bad connector if not examine the ribbon. | |
| Thank you both Finally i found the problem and fixed it two of the wires to the display were broken | |
| LCD 2x16 Demo for the Unicorn (18F4550) | blueroomelectronics | Micro Controllers | 21 | 31st October 2008 05:17 PM |
| Atmel, assembly:displaying on lcd | Haidy | Micro Controllers | 13 | 11th February 2008 09:13 PM |
| HD44780 LCD operation | ssylee | Micro Controllers | 25 | 15th December 2007 01:52 AM |
| PIC16F628A LCD problems. | HerbertMunch | Micro Controllers | 17 | 2nd October 2007 10:20 AM |
| Newbie needs help with LCD backlight dimming | Mongoose | General Electronics Chat | 6 | 22nd September 2007 12:23 AM |
