| | #16 |
My night lights are 5W incandescent outdoors Christmas tree bulbs. They have an LDR that turns them off in the daytime. They shine all around and don't blind you. Each bulb lasts about 6 months.
| | #17 |
what components used in solar LED street light? | |
| | #18 |
| | #19 |
| | #20 |
I have never seen a solar street light. The solar panel will need to be huge and expensive. There must be many expensive high power LEDs. There must be a huge battery so that it can light all night after a week or more of clouds. A solar garden light has a small cheap solar panel, a single small LED, a single Ni-Cad battery cell and a few parts to stepup the voltage. Some add an LDR to turn it off in the daylight and others use the solar panel to detect the daylight.
| | #21 | ||
I want to make it but I face some problems I hope you could help me: 1- I could not find in my country ICM 7555 its not available at all so I searched and find normal 555 so I want to ask you will it fit instead of the 7555 and when I use 555 do I need to change any values of the resistance? 2- Also I could not find 1N914 and they told me 1N4148 H is the same...what do you think? 3- concerning the resistance values I want to be sure from R1 and R2 you mentioned R1 820 do you mean ohm or kilo and R2 390 Ohm or kilo just to be sure as I know values are very critical in that circuit 4- As for the red LED light in the night is it good I mean one can see from it? Or we need stronger light source and how could we implement it in the circuit? Thanks again and sorry for disturbance... Quote:
1- You used R1 820 Kilo and R2 390K and collector resistance 390 Ohm am i right? 2- The transistor you used, which model or any one can fit; please recommend one for me And if you have any comment on the above questions your advice is appreciated Many thanks to all of you ![]() | |||
| | #22 | ||
I want to thank you very much for that very nice idea and I want to make it my self... But I’m facing some problems I hope you could help me 1- I could not find in my country ICM 7555 and after I searched I found only 555 is available so can I replace the 7555 with the 555 with out changing the circuit values? 2- The values of R1 and R2 I want to be sure about them are they R1= 820 ohm and R2= 390 ohm and not kilo ohm? 3- Also the diode 1N914 not available in my country so could I replace it with 1N4148 H they told me they are the same what do you think? 4- For the red LED light in the night is it ok, I mean one can see from it? And can we add more powerful light source in that circuit? Many thanks again and sorry for the disturbance.... Quote:
Thanks for your support and nice modification but I need some clarification from you 1- The transistor you used is which type or mode could you recommend one for me 2- The values of R1 and R2 I want to be sure about them you used R1= 820 Kilo ohm and R2= 390 Kilo ohm and collector resistance 390 ohm right? Also if you have any comment on my above question your advice is appreciated... Thanks to you all | |||
| | #23 | |||||
The ICM7555 is a Cmos 555 made by Intersil. As I said earlier in this thread, the LMC555 is exactly the same made by National Semi and the TLC555 is exactly the same made by Texas Instruments. The old original 555 is completely different and would need to have the resistor values changed to work if it works in this circuit. Quote:
The values are shown on the schematic. Quote:
The 1N4148 diode will work fine. Both the 1N914 and 1N4148 are affected by light so put black tubing around it. Quote:
RED LEDs do not produce much light. I don't know if a white LED will work since it has a phosphor. Quote:
Any little NPN silicon transistor is fine. 2N3904 or BC547.
__________________ Uncle $crooge | ||||||
| | #24 | |
Many Thanks audioguru you really helped me a lot ![]() | ||
| led, light, night |
| 230 Volts LED night light project | RODALCO | Electronic Projects Design/Ideas/Reviews | 22 | 22nd March 2009 03:07 AM |
| Help with night light system | ZackSmith | Electronic Projects Design/Ideas/Reviews | 4 | 25th September 2008 11:24 PM |
| LED christmas light switch (what would you call a circuit like this?) | Andy1845c | General Electronics Chat | 14 | 1st December 2007 04:24 PM |
| LED to light when load detected? | NewUser | General Electronics Chat | 5 | 5th October 2007 11:28 AM |
| looking for circuit that turns light on at night off during day | mettam | Electronic Projects Design/Ideas/Reviews | 15 | 5th September 2006 04:30 PM |
