| I am using a sharp GP2d12 IR sensor with a 4.8 V battery and trying to power a vibration motor. The motor requires a 80 mA current to start and has an operationg range of 2 -3.6 V. Unfortunately the sensor only supplies 5mA and ranges in voltage from .5-2.6 V. What OPAMP or other device can I use to get this motor to vibrate harder, the closer the object is to the sensor? | |
| Rotary vibration motors have an eccentric weight attached to the shaft. The only parameter you can change is the frequency of vibration, not the intensity. Is that what you want? | |
| I think that any conventional Power amp basically of an OP-Amp (LF351 not sure check data sheet)and couple of transistors can help you out if not post complete detail may be i can reply helpful. | |
| Sure you can change the intensity of a vibrator. Vibrators have a variable resistance in series which can increase the power to the motor enough to vibrate her socks off! Then the frequency (the RPM of the motor) also increases.
| opamp TLO-82 datasheet needed | dudeshan | General Electronics Chat | 8 | 28th October 2007 03:20 AM |
| opamp audio mixer - single supply | fvnktion | General Electronics Chat | 7 | 11th July 2007 08:16 PM |
| Configurable opamp model for Spice | Optikon | General Electronics Chat | 0 | 1st February 2007 06:55 PM |
| Light sensor with LED's | mcs51mc | Electronic Projects Design/Ideas/Reviews | 13 | 7th July 2006 06:34 AM |
| Opamp Vo Vin lag: Cancelled using another lag | eblc1388 | General Electronics Chat | 6 | 1st May 2005 11:51 AM |
