Old 20th March 2008, 01:06 PM   (permalink)
Default Convert 15V to 13.8
I have a 15Volt 20 A Charger i want to get 13.8Volt from it .
How can i do that with components handel the 20A
AboZakaria is offline
Old 20th March 2008, 01:17 PM   (permalink)
A linear voltage regulator is probably not the best option because of the high current requirement (of course that current depends on the device). If you are going to be drawing <1 amp, a linear regulator might be an option.
If you are drawing 20 amps, you will need something like a switching power supply, but be aware that these introduce a lot of noise into your system and aren't appropriate for every application.
If you want an easy solution, put two large diodes(that will handle the current you need) in series in your circuit. 0.7 volt drop on each one = 1.4 volts, and there you have it, 13.6 volts.
slosjo is offline
Old 20th March 2008, 06:21 PM   (permalink)
the idea of the diode is good
you can also try to connect series variable resistance
and put it on max then try to reduce until you get the voltage you want
good luck
emission is offline
Old 20th March 2008, 06:43 PM   (permalink)
15 volt charger? are you sure of the battery voltage or is that an open circuit voltage you measured. I don't remember ever seeing a 15 volt battery..
But then again,there's a lot I don't remember, just ask my wife.....
gerty
gerty is offline
Old 20th March 2008, 07:13 PM   (permalink)
Gerty appears correct. if you load it by say 0.5 amp, it will come down to 13.8V
Regards,
Sarma.
mvs sarma is online now
Old 20th March 2008, 09:29 PM   (permalink)
Thanks alot
Hi gerty if you want to fast charge a 12V lead acid battery the charge voltage ~ 15 Volt and float volt ~ 13.8
Old 20th March 2008, 09:58 PM   (permalink)
I disagree, a linear regulator is an excellant choice here because the voltage drop is very low which will give 92% efficiency - much better than some switching regulators!
The only problem is finding a linear regulator with a low enough dropout voltage than can handle the current.
Screen name: Aloone_Jonez
Hero999 is offline
AVR: PWM for convert a digital signal to analoge! kasser Micro Controllers 3 12th July 2007 03:03 PM
Convert voltage regulator to constant current regulator? goldserve Electronic Projects Design/Ideas/Reviews 10 11th September 2006 06:39 AM
Trying to convert binary to ascii ChriX Micro Controllers 9 7th May 2005 01:30 PM
HOW TO CONVERT HEXA TO DECIMAL FOR LCD, PLS HELP!!!!!!!! AUNG THANT Micro Controllers 3 10th April 2004 01:38 PM
convert... bogdanfirst Electronic Projects Design/Ideas/Reviews 16 6th April 2003 04:19 PM
