Old 17th March 2008, 10:27 AM   (permalink)
Default Noise on the power supply line
Hi
I have two circtuis on a common ground. The voltage on each circuit is regulated by its own V regulator (LP2951): One at 3.0V the other at 5.0V.
The 3.0V supplies a SD card, the 5.0V supplies a set of sensors.
What I notice is that every time the SD card is written to, there is a voltage (up or down) spike on the 5.0V supply!
I am using a 68uF cap on each of the V regulators.
Can someone please help me in eliminating/ reducing the V spikes on the sensor 5.0V regulated supply?
Thank you in advance.
a.
arrow is offline
Old 17th March 2008, 11:08 AM   (permalink)
Have you got 0.1uF capacitors in parallel with the 68uF ones?
Edit corrected as per Nigel's post.
Pommie is offline
Old 17th March 2008, 11:16 AM   (permalink)
HI Mike
Thank you for your suggestion.
I have just added a 0.22uF cap in series with the sensor 68uF cap, and I still get the spikes on the sensor power line.
I have a 0.22uF cap. close to the SD chip.
(I have never understood why one would need a small capacitor in series with a larger one. Does it matter what kind of capacitor it is? - I think I am using a tantalum for the 0.22uF)
Thank you
a.
arrow is offline
Old 17th March 2008, 11:31 AM   (permalink)
Have a read of this page.
Pommie is offline
Old 17th March 2008, 11:34 AM   (permalink)
Originally Posted by Pommie
Have you got 0.1uF capacitors in series with the 68uF ones?
Surely you mean in parallel?.
Old 17th March 2008, 12:04 PM   (permalink)
I do indeed.
Pommie is offline
Old 17th March 2008, 12:21 PM   (permalink)
Hi arrow,
try this:
The 47n capacitors already take care of reduced spikes from mains via the transformer. Additionally connect a small inductance (47 - 100µH) + a 100n capacitor close to the power supply pin of the card reader/writer. Doing the same with the connected sensors spikes and resulting problems should be minimized.
Finally use separate GND traces from the power supply to the sensors and to the card reader/writer.
Boncuk is offline
Old 18th March 2008, 08:27 AM   (permalink)
Hi
Thank you all for replying. I tried most of the above, and it did not seem to work. I ended up putting in an RC low pass filter with R=1ohm and C=0.022uF, and that worked pretty well.
All the best
a.
arrow is offline
Old 19th March 2008, 07:55 PM   (permalink)
What current are you drawing, are you sure you can stand the voltage drop across the resistor?
You could have also tried an inductor or just a simple ferrite bead.
Screen name: Aloone_Jonez
Hero999 is offline
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 28th August 2007 12:06 AM
Got a new EVBoard How do i supply power to it? cubdh23 Micro Controllers 2 3rd August 2007 10:39 AM
Linear Unregulated Power Supply jbchrist Electronic Projects Design/Ideas/Reviews 19 16th February 2007 11:10 AM
24v DC Power Supply (Help & Information Wanted Urgently) ampthetex Electronic Projects Design/Ideas/Reviews 5 17th November 2006 01:45 PM
Using old power modem power supply mongoq General Electronics Chat 2 24th February 2005 09:05 PM
