Old 13th March 2008, 08:34 PM   (permalink)
Experienced Member
SeanHatch is on a distinguished road
Send a message via AIM to SeanHatch
Default PIC18F interrupt
Hi;
I have been working on this interrupt for a while now, and I can't get it to work. I'm trying to turn on or off an LED with a push button.
I have a PIC18F452
Here is the code:
#include <p18cxxx.h>
#pragma config WDT=OFF
#pragma config LVP=OFF
#include <ADC.h>
#include<math.h>
#include<portb.h>
void change(void);
#pragma code HIGH_INTERRUPT_VECTOR = 0x8
void high_ISR (void){
	_asm
	goto change
	_endasm
#pragma code
#pragma interrupt change
void change(void)
        PORTDbits.RD0 = !PORTDbits.RD0;
	INTCONbits.INT0IF = 0;
void main()
		TRISD = 0b11111111;
		//TRISB = 0b00000000;
		RCONbits.IPEN = 1;
		INTCONbits.GIEH = 1;
		OpenRB0INT (PORTB_CHANGE_INT_ON &
					PORTB_PULLUPS_ON &
					FALLING_EDGE_INT);
	   for(count = 1; count < 10000; count++);
           while(1)                        // forever
				//PORTDbits.RD0 = !PORTDbits.RD0;
               	                //INTCONbits.INT0IF = 1;
				for(count = 1; count < 5000; count++);
I know I'm pretty close. If I uncomment the line INTCONbits.INT0IF = 1, the interrupt functions as it should. So I know that the interrupt is properly coded and stuff.
Also, I know that the button works. I have a multimeter on the RD0 pin, and it is changing from 5V to 0V when I push the button.
Basically, the voltage change on the RD0 pin is not setting the INT0 flag, and I don't know why? Am I missing initializing something?
SeanHatch is offline   Reply With Quote
Old 13th March 2008, 10:54 PM   (permalink)
Experienced Member
Hmm, I cannot even get one of Microchip's interrupts to work. I've tried the one found in this document: alumni.ipt.pt/~wilson/PCBDriller/_private/MPLab_get_started.pdf
(example 4)
and it still won't work!
Old 13th March 2008, 11:52 PM   (permalink)
Experienced Member
aussiepoof has a spectacular aura about
I'm a little confused... the RDO pin can't set the INT0 flag as only RB0 can do that...
Surely the button should be on RB0 and the LED on RD0?
P.
aussiepoof is offline   Reply With Quote
Old 13th March 2008, 11:54 PM   (permalink)
Experienced Member
P.
Yes you are correct. Typo. RB0/INT0 is switching between 5 and 0 volts according to the position of the switch.
Old 14th March 2008, 12:08 AM   (permalink)
Experienced Member
Cool... just checking before I jumped in :-)
Try:
LATDbits.RD0 = !LATDbits.RD0;
P.
Old 14th March 2008, 12:22 AM   (permalink)
Experienced Member
Oh, and TRISD = 0b11111110
P.
Old 14th March 2008, 12:29 AM   (permalink)
Experienced Member
Ha, I noticed that TRISD thing a few minutes ago (, still a no go.
Also, I'm not sure LATDbits will do anything (I don't even know what the difference is; will research), because when I set the INT0 flag myself, everything works as supposed.
I'm still pretty sure its just a matter of setting the flag
Thanks for your input though, I'll keep working.
Old 14th March 2008, 12:47 AM   (permalink)
Experienced Member
Ok... you need to do the following I think.
In the interrupt routine read port B, and set INTCON.RBIF RB0 to zero to clear the external interrupt.
P.
PIC16F628a Problem generating a RCIE interrupt Norlin Micro Controllers 3 16th January 2008 01:43 AM
Priority Interrupt Controller Stellarcore Datasheet/Parts Requests 14 13th September 2007 04:13 PM
16F877 Timer0 Interrupt Affecting ADC sebana Micro Controllers 13 12th September 2007 09:42 AM
Question about Interrupt tinhnho Micro Controllers 3 11th February 2007 07:07 PM
HANDLING THE INTERRUPT. alamy Micro Controllers 6 26th March 2005 03:37 PM
