| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | I've recently become interested (again) in maybe getting some wirewrap equipment to prototype with. (I always seem to get lazy and layout a PCB and trying to route so many signals over a limited number of layers and then send it away only to find there were expensive irreversible mistakes). Anyways, I thought this was neat: http://techref.massmind.org/techref/pcbwires.htm But I don't quite understand the details. The person also seems to make a comparison to wirewrap but the translation is a bit floppy so I don't understand. Can anyone else make better heads or tails of it? |
| Moderator | It is slick way of doing point to point wiring. He cuts all the component pins off flush with the board. If you are doing 2 layer boards when you make a mistake you can cut traces and wires as in point to point. What Cad package did you settle on ? If you hand wire the board it puts you one step further away from a final layout.
__________________ To control the world from your PC with USB I suggest USB Bit Wacker 3v0's Tutorials for ABSOLUTE BEGINNER C, PIC 18F, MPLABŪ and MCC18 Compiler |
| Moderator | The last guy I knew that used wire warp quit about a year ago. Wire wrap connections may not fall apart but their ability to conduct current can degrade with tme. At least that is what I have seen. I forgot that you were using Eagle because you instructor would not let you use OrCAD.
