Hi everyone, I need to be able to sense the room temperature quite accurately (+/- 0,1°C for a temperature range between 15 and 25°C - I should be nevertheless able to measure from -10°C to +45°C) using a KTY 10-62 silicon temperature sensor. The measurement current should be around 1 mA, and I will use a 10-bit A/D converter (PIC 16F877A). For a ~1mA current, the voltage drop at 15 °C will be 1mA x 1846 Ohm=1,846V and 2 V at 25°C. This leaves us a deltaV of 164mV. If the 0-5V is represented by 10 bit, I get around 5mV per division, which in turn leads to ~33 divisions between 15 and 25°C --> the precision is then +/- 0,3 °C How can I improve things to "expand" the full range (-10°C-->1496Ohm to +45°C-->2331 Ohm) to the 0-5V acquisition range of the ADC? Thanks a lot! | |
Use an opamp, and also use a precision voltage reference to give a 0-2.5V range, rather than the less accurate 5V Vdd rail.
Just use an LM92 The KTY 10-62 is only accurate to +/- 0.5 degrees so you would need to calibrate for better accuracy. http://cache.national.com/ds/LM/LM92.pdf is good to +/- 0.50 degrees over the range that you want. The output is digital, so no messing about with anything analog. The resolution is 1/16th deg C, and you can add a calibration offset in code if you want to. | |
| | #4 | |
http://rts.uni-mb.si/misc/materiali/mikrorac/kty10.pdf Secondly, the PIC's A/D is very noisy for slow changing signals like temperatures. You will have to do some Gaussian filtering and multisample averaging to get anything good out of it. I would recommend an external integrating A/D to boot. I would seriously consider a different sensor, and different A/D scheme here for the range you want. Gaining up your signal will only add to the noise, so some analog filtering would also be a good bet. Hope that helped.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | ||
| | #5 | |
| | #6 | |
| | #7 | |
| | #8 |
Any A2D is +/- one bit, a PIC 10 bit A2D happily outputs this accuracy if fed from a constant voltage, and a slowly changing one is no problem. As suggested, by averaging the readings you can effectively filter the results. I can see your point for 16 bit conversions, but for only 10 bits I don't see any problems?. | |
| | #9 | |
| | #10 |
Thanks a lot everyone! I've surely learnt a lot! For the time being, and taking into account that the only thing I've found at the local store was the KTY 10-62s, I think I will follow Nigel's suggestion. One question: How can I get a "precision voltage reference" of 2,5V? I'm currently feeding the circuit with 9-12V, and using a 7805 to get 5V. As for the LM92, I've asked them and they don't have it :-( I have used before an I2C temperature sensor, but it was 7 bit and had a crappy precision/reproducibility (I don't remember the reference, it was long ago and a bad first experience in the world of µcontrollers with a BASIC-based one). Last edited by winterhunter; 11th March 2008 at 02:39 PM. | |
| | #11 |
Check my analogue tutorial, it uses such a reference, and explains how to use the A2D as well - it also shows one way to use an opamp.
| amplify, range, sensing, temperature, voltage |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| Current limiting Help PLZ | Frosty_47 | General Electronics Chat | 32 | 24th July 2007 04:51 PM |
| Z8 Encore Error index out of range | mootaccount | Micro Controllers | 2 | 17th October 2006 03:23 PM |
| Newbie needs some help | Kenny.s | Electronic Projects Design/Ideas/Reviews | 17 | 3rd July 2006 11:22 AM |
| Real world test measurements? | SomeoneKnows | General Electronics Chat | 8 | 26th August 2003 07:38 PM |
