| Hi, I have a 240V: 2500V AC transformer, 1VA, 50hz. 1. I want to control and reduce the secondary from 600~2500V, can I use a light dimmer to control the Primary input? Will it do the trick? 2. Will it be very dangerous if I accidently touch the 1VA, 0.0004A, 2500VAC? Thank you, Victor | |
| A dimmer uses a Triac, and therefore its output is not purely sinusoidal. Because of this, the transformer is subjected to a highly distorted waveform with a lot of harmonics. If that's okay for your load side, then this could potentially work, but is not an ideal solution. The high frequency content of the distorted waveform is also hard on the windings of the transformer. It may also be severe enough to hear when standing next to it. As far as the danger of touching 2500V, I wouldn't recommend it. Would you trust the rating of the transformer? What if they're off by a factor of ten? This is a dangerous voltage!
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
| Is there other method to control output voltage of a transformer for my case? | |
FM...
__________________ When God was handing out the brains, I thought he said trains, so I asked for a small, slow one! | ||
| Use a variac to alter the input voltage from 0 to 240V.
| Yeah, a variac would be your best bet, though they can get kinda expensive. If you need control though, a variac is the only way really.
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
| So, variac's ? Can I control the input voltage on the drive H.O.T on tv set without saturating it ? Let's say to put the anode to the cathode to draw an arc ? And what is the danger of radiating myself in the process ? | |
| High voltage | Armagdn03 | General Electronics Chat | 30 | 29th November 2007 11:10 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Major Help Needed Please: Peltier and 2 channel fan controller needed :S | MR Spade | General Electronics Chat | 16 | 23rd November 2007 04:10 PM |
| Effects | stephenpic | Micro Controllers | 6 | 19th January 2004 12:57 PM |
| should i use a voltage regulator on a wall transformer. | macman828 | General Electronics Chat | 3 | 22nd April 2003 08:11 AM |
