| Im trying to work out what resistor should I use for a school project but I keep getting confused I need to drop a 6V input to a max of 5.25V output but a min 4.25V, can anyone help me out with this? Kind regards -Vincent | |
| Apply your Ohm's Law. | |
| Two diodes in series will drop it to 4.6V What are you powering? Mike. | |
| If you don't know what current the device will draw then a resistor is no use. The simplest method is to connect two diodes in series with the positive supply - 1N4001 will handle 1A and USB can only supply up to 500mA. Mike. | |
| Where are you getting the power supply from? Use a low droput regulator. Be warned, if it's four AA cells, the voltage will quickly drop to below 5V which where even most low droput regulators stop working.
| hello, Voltage dividers are good as long as the current drawn by the load is low (10 x less ) compared to the current flowing in the resistors network. now if you do not have a fixed load or if the load takes up too much current your best bet is either a low drop out voltage or diodes in series.... best of luck Antonio | |
| Major Help Needed Please: Peltier and 2 channel fan controller needed :S | MR Spade | General Electronics Chat | 16 | 23rd November 2007 04:10 PM |
| opamp TLO-82 datasheet needed | dudeshan | General Electronics Chat | 8 | 28th October 2007 03:20 AM |
| How to actually specify the capacitor needed? | Migs | General Electronics Chat | 8 | 26th September 2007 06:12 PM |
| "Sip n Puff" Trigger Help Needed. | hook848 | Electronic Projects Design/Ideas/Reviews | 11 | 8th September 2004 04:36 AM |
| Help me! Needed pin-out and/or data sheets | dddarie | Datasheet/Parts Requests | 5 | 30th June 2004 10:39 PM |
