Old 7th March 2008, 02:52 PM   (permalink)
Default A Mystery of Life
There are some things in life that just. don't. make. sense.
For example, why do we drive on parkways, but park on driveways?
Something very important that just. doesn't. make. sense. is the fact that most TTL chips and many CMOS chips require 5 volts, when that voltage is impossible to achieve using 1.5 V batteries.
My questions? How do you go about supplying 5.0 Volts to a circuit? Wall outlet + transformer? Specialty battery?
If it is broken, let's fix it.
If it is working, let's make it better.
NightFalcon90909 is offline
Old 7th March 2008, 02:56 PM   (permalink)
4 or more batteries and a voltage regulator. Or fewer batteries and a stepup DC-DC converter.
IČR is offline
Old 7th March 2008, 03:16 PM   (permalink)
Nowadays 5V 1A switchmode wall adapters are cheap. Works great. Else a simple 7805 power supply.
Bill
Smart Kits build Smart People
Old 7th March 2008, 03:26 PM   (permalink)
if you know the reason so you'll never think of it as a mystery ,
for example why the week is 7 days ?.......why not 8 or 6 ?
think of it ...... if you thought it's a mystery too tell me and i'll tell you reason
watzmann is offline
Old 7th March 2008, 05:25 PM   (permalink)
I don't know what driveways or parkways are?
They must be an American thing.
Here in the UK a drive is a short piece of private road connecting one's house and one's garage, is that what a driveway is in the US?
You use a low dropout regulator and a 9V battery to give you 5V.
Most CMOS ICs will run from 3V to 15V (some 18V) which will work fine from 3 to 9 AA cells or a 9V battery.
HC CMOS ICs will run from 2V to 6V and will run from a couple of AA cells.
Always take the discharge graph of AA cells into account when using them with your circuits. Assume 1.6V per cell when the batteries are brand new and 1V per cell when they're dead.
You can buy regulated 5V wall adaptors or connect an LM7805 regulator to a 9V adaptor. It's possible to build your own power supply from a 9V 1.5A transformer, a bridge rectifier, a 3,300”F to 10,000”F capacitor and an LM7805 regulator.
Screen name: Aloone_Jonez
Hero999 is offline
Old 7th March 2008, 05:32 PM   (permalink)
Cool
For small 5 volt power supplies I've used old chargers from broken/obsolete cellphones ..Almost always free.
gerty
gerty is offline
Old 7th March 2008, 05:35 PM   (permalink)
Yes.
A parkway is one sort of toll road here.
IČR is offline
Old 7th March 2008, 06:27 PM   (permalink)
CMOS supports voltages as low as around 3V, but that extra volt does help quite a bit, since it allows the circuit to continue running even after the batteries drop in voltage output.
Salgat is offline
Old 7th March 2008, 08:46 PM   (permalink)
A 6V battery supply, for instance from four AA batteries, plus a 7805 voltage regulator will supply regulated 5V for longer than if the battery supply was initially 5V. As the 6V battery supply is used, its voltage will drop, but as long as it stays a bit above 5V, the 7805 will continue to supply regulated 5V.
Parkways and driveways? What about hemorrhoids and asteroids? That one always seemed mixed up to me.
Hank Fletcher is offline
Old 7th March 2008, 09:23 PM   (permalink)
Old fashioned TTL uses too much current for a battery. So you need a power supply to heat them up.
Ordinary Cmos works with a supply from 3V to 18V at low current.
High speed Cmos works with a supply from 2V to 6V at low current.
In Canada, I have never seen a toll road.
A parkway is a pleasant drive in a park or beside a river or lake.
My son put some rubber stripes in my driveway.
audioguru is offline
Old 7th March 2008, 09:33 PM   (permalink)
No it won't, depending on the regulator and current draw, the voltage drop will be anything from 1.5V to 3V.
Assuming it's an alkaline, the bettery voltage will quickly drop to about 5V which will be (worst case) 3V after the regulator.
To get any usable battery life, you need to use a low dropout regulator and a 9V battery for TTL.
Hero999 is offline
Ball Lightning Mystery Solved? Electrical Phenomenon Created in Lab Analog Chit-Chat 16 27th January 2007 04:09 PM
resistance/battery life meterman Electronic Projects Design/Ideas/Reviews 6 28th October 2005 05:16 AM
Cap Life Span ? iso9001 General Electronics Chat 14 6th May 2005 02:44 PM
Battery Life for an LCD Watch Watches Electronic Projects Design/Ideas/Reviews 6 3rd April 2005 05:14 PM
Extended Battery Life Bakofoil Electronic Projects Design/Ideas/Reviews 2 26th September 2004 02:45 PM
