| Hi All , i'm running a stepper motor with a supply from LM7805 , my problem is the stepper draws more than 1.3 A , so the regulator goes so hot in a few seconds , i need to use another regulator LM too , but can stand this high current , i know the 138, 338 ..... i don't like them they are variable , i need a constant one like the 7805 and high current could you suggest one please , Thank you | |
| Possibly the TS108X series, don't know whether they go up to 5V though. | |
| Does the regulator have alarge heat sink? What about using an LM317 which can handle 1.5A. The chances are that your LM7805 is fine but you haven't got it on a decent heat sink.
| Lm78S05 and you're going to need a heatsink. | |
| o.k , i can fix a heatsink , but i think this wrong too , the datasheet says it just for 1 Amp , so why i use it with more than that ??? | |
| The chances are it'll stand up to 1.5A but use the LM317 which requires a couple of resistors if you have any problems.
| What is your input voltage ? If your input-output voltage is too large then it will heat up a lot more quickly. Even the LM338 will shut down quickly if you try powering something that takes a couple of amps at 5v if you're using a 30v input. | |
Why are you regulating stepper motors anyway? | ||
| You have three choices to get a higher current than 1A. The - LM78S05 delivers 2A, - LM7805K delivers 3A (TO3 package) - LM7805 delivers any current if you boost it with a power transistor. (The max. current splits into two currents where the LM7805 will stay at 800mA if the dimensions are correct.) All of them require a heat sink! Bosco | |
He should use the unregulated supply for the motor and just use 5V for the microcontroller.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | ||
| Hi Watzmann, Here's one, but you're gonna need a large heatsink because it will run as hot as the previous one. http://cache.national.com/ds/LM/LM323.pdf? on1aag. | |
| It's a switching regulator, therefore it will require a large heatshink.
__________________ E Cerfoglio Buenos Aires Argentina | ||
| Sorry, I meant linear regulator.
| Need help about a 7805 regulator circuit ! | Zarkabul | Electronic Projects Design/Ideas/Reviews | 31 | 13th October 2008 05:35 PM |
| LDO replacement for 7805? | Krumlink | Datasheet/Parts Requests | 32 | 11th September 2007 01:33 AM |
| problem with 7805 | mnoman | Electronic Projects Design/Ideas/Reviews | 1 | 7th November 2006 10:09 PM |
| Capacitor specs for use with 7805 regulator | loosewire | General Electronics Chat | 2 | 11th January 2005 10:39 PM |
| Doubling 7805 current capacity? | charliez | General Electronics Chat | 7 | 12th August 2004 04:58 AM |
