Old 5th March 2008, 03:48 PM   (permalink)
Default Urgent help needed ! Structure for project
Guys,
Need some help urgently! I have a thin shaft and a rectangular solar panel. The shaft is connected to a motor shaft and will rotate. How do I stick the panel onto the shaft so it can rotate ?
The simpler the solution the better..
Thank you everyone
rngd is offline   Reply With Quote
Old 5th March 2008, 04:07 PM   (permalink)
With glue.
You're not being very clear, are you building a solar follower?
How big is it?
If it's just a small pannel you're probably wasting your time as all the extra energy will be wasted powering the motor that turns it.
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
Old 5th March 2008, 04:10 PM   (permalink)
Hot glue, duct tape, canadian chewing gum...
How big a panel, shaft, motor? Panel have any kind of framework? Is the shaft strong enough to support the panel? What will the wind do (assuming this will be outside under the sun). How about some pictures, links, or some sort of scale.
Is this for power, or as a light sensor? So many posiblities, any other guesses?
HarveyH42 is offline   Reply With Quote
Old 6th March 2008, 12:22 AM   (permalink)
What's so special about Canadian chewing gum?
McIntosh toffee, now that stuff will pull fillings out of your teeth.
Bill
Smart Kits build Smart People
Old 6th March 2008, 09:43 PM   (permalink)
Canadian Chewing Gum is hard like steel after it has been sitting in the snow for a while.
Old 7th March 2008, 01:57 AM   (permalink)
what kind of material is the shaft and your frame work of your sollar panel???
welding could be a solution
what are the envoirement conditions the thing has to oparate in tropics blizards high winds monsoon rains ???????
rjvh is offline   Reply With Quote
Old 7th March 2008, 03:03 PM   (permalink)
Two days, guess it wasn't that urgent after all...
I've been sort of getting the solar bug again. I've got a 12 watt panel, a 5 watt charger/controller, and a 12 volt/7AH SLA to play with. Should have plenty from the panel for a tracker. But then again, should be able to charge that tiny battery easy without chasing the sun. I was going to use the hardware an actuator from the old satelite dishes I have.
To the OP, there is an alternate energy site called REDROCK (search, easy find), that has hundreds of photos and diagrams, and about as many links. Page takes for ever to load (dial-up), but you should have no problem finding something that fits your needs. My 12 watt panel would be a little small compared to most of the stuff the have, but you can scale to your needs.
Old 8th March 2008, 05:19 PM   (permalink)
Very very very sorry guys. For some reason I did not get any emails about replies to this topic (normally i do), so I did not check back here thinking nobody replied..
I actually decided to use epoxy (Araldite) to glue the shaft onto the perspex frame that is holding the solar panel. Its a small 5W panel and the shaft is 5mm in diameter.
Ive been to that site, but they only show few pictures of the trackers, and it was very hard to see how the frame was constructed.
Thanks for the replies anyway guys.
VERY URGENT HELP NEEDED PLEASE SOTX Electronic Projects Design/Ideas/Reviews 9 8th November 2005 06:16 AM
Massive ERRORS in program. URGENT HELP NEEDED. davepusey Micro Controllers 8 18th May 2004 04:13 AM
Urgent help needed scout_54 Electronic Projects Design/Ideas/Reviews 0 28th March 2004 11:40 AM
URGENT HELP NEEDED sumitkaul Electronic Projects Design/Ideas/Reviews 0 29th September 2003 02:07 PM
Urgent help needed Skyknight Electronic Projects Design/Ideas/Reviews 6 20th May 2003 08:36 PM
