+ Reply to Thread
Results 1 to 7 of 7
Thread: Low pass filters & Notch Filter
  1. #1
    maidmarion Newbie
    Join Date
    Mar 2008
    Posts
    2
    Default Low pass filters & Notch Filter
    Hi just a few questions if anyone can help me on -
    1) Can anyone please advise me on what the vocational uses are for a Notch Filter?
    2) When setting up an investigation for a Notch filter what sort of components would be used?
    3) When 2 low pass filters are in cascade, why does the slope become steeper?
    4) What is the relationship between the -3dB and cut-off frequency in a low pass filter circuit?
    Any help would be so appreciated!
    Laura
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by maidmarion
    It removes a narrow range of frequencies. I use a notch filter in my harmonic distortion analyser circuit to remove the fundamental frequency of a sine-wave so that measurement can be made of only the harmonics.
    Look at Notch Filter in Google. An opamp, some resistors and some capacitors are usually used to make a notch filter. I made one with a switched-capacitor Butterworth filter IC.
    The slope is also cascaded. The attenuation is doubled at a frequency past the cutoff frequency.
    The -3dB frequency is called the cutoff frequency. The cutoff frequency of a single-order Butterworth filter is calculated by 1/(2 pi RC). The calculation is more complicated when the filter has more orders.
  3. #3
    IČR Okay
    Join Date
    Mar 2008
    Location
    Richmond, VA
    Posts
    87
    A more common and familiar use for notch filters is in the analog cable industry. Cable distributors use notch filters to prevent a particular installation from receiving certain--usually premium--channels. When you subscribe to one of these channels a technician removes the appropriate filter from a special pole-mounted enclosure and you're then able to receive it.
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by IČR
    But that really old crude technology, surely no one uses analogue cable these days?.
  5. #5
    KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,385
    A common use for notch filters is in medical equipment used to record ECG/EEG/...signals. All have notch filters for 60Hz (or 50Hz) that filter out the interference radiated from the buildings' power wiring.
    Ken
  6. #6
    ecerfoglio Newbie
    Join Date
    Jul 2007
    Location
    Buenos Aires
    Posts
    177
    Also, if you want to receive some radio / TV station that is close (in frecuency) to a powerfull local transmiter, then a notch filter between the antena and receiver often helps to reduce interference.
    E Cerfoglio
    Buenos Aires
    Argentina
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Cable TV in Canada is a combination of old analog and new digital.
    All stations are available as digital with better picture and sound than analog.
    Old broadcasted stations are available as both. New cable-only stations and pay TV are digital-only. A converter is needed to select and decode them.
    Years ago before digital, I saw the cable TV box down the street over-stuffed with notch filters for everybody who did not pay for extra channels.
    Then they added new notch filters at each home where the cable enters.
    I had one and it messed up my reception of ordinary channels so I complained and they removed it.
+ Reply to Thread
  1. Low pass Active RC filter + PSPICE
    By MrNobody in forum General Electronics Chat
    Latest: 28th February 2008, 12:44 AM
  2. low pass filter sample diagram
    By allan josephus in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th February 2008, 04:22 PM
  3. Amplifier low pass filter
    By richard.c in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th February 2008, 10:05 PM
  4. Low pass audio filter
    By steven_first_2001 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd January 2005, 06:36 PM
  5. Audio Notch Filter
    By ElectroMaster in forum Electronic Projects
    Latest: 25th July 2002, 01:11 AM
Tags for this Thread
