Hi guys
if i want to clamp a 10MHz, 2V p-p sinusoidal signal at +-400mV, what is the easiest way of doing this? At the moment i am using the properties of diodes (1N4148, 0.7V volt drop), which succesfully clamp the signal @ +-0.7V. but it is stll higher than the siganl that i want (+-0.4V) I am now thinking using some fast schottky diodes, which has got a lower voltage drop. But i do not know what other schottky diodes are availabe? (The only schottky diode that i know is 1N5819...) Thanks |
How about a simple attenuator after the diode clamp?.
i hav thought about that, but for that way it's going to introduce more phase shift to the output signal...which is what i m trying to avoid...
it will be great if i can clamp the signal in just one stage! |
And how does a resistive attenuator introduce phase shift?
Experience is directly proportional to the value of the equipment ruined. |
Hi Hykwei
About the diodes you could use BAT81 . . . 83 or the BAT85 which has an even lower forward voltage drop. Other possible candidates are 1N5711 & 12 and the 5082-2300, 5082-2800 and 5082-2900. on1aag. |
well...that is what i observed from the output of the attenuator...it does introduce more phase shift when i compare the input and output using oscilloscope...
i suppose every components(even resistor) has got internal capacitance, and under a high frequency system (MHz range), those capacitance becomes more significant + introducing phase shift, doesn't it? This is what i think...please correct me if m wrong! Thanks |
What value resistors were you using, and what were the source and load impedances. |
the resistor value is 20k...is that too large?
The signal comes from a signal generator. |
Also, are you using a x10 probe on the scope?, the scope capacitance will cause phase shift with your large resistor. |
| Will a rectifier diodes work as protection diodes in a relay app? | Andy1845c | General Electronics Chat | 12 | 15th November 2007 09:42 PM |
| Checking out diodes ... ? | john1 | Electronic Projects Design/Ideas/Reviews | 5 | 18th May 2006 10:46 PM |
| Question regarding Protection Diodes in Power Supply Project | marksinga | Electronic Projects Design/Ideas/Reviews | 3 | 19th November 2005 10:56 PM |
| Diodes and blocking... | Styx | General Electronics Chat | 2 | 21st May 2005 08:25 PM |
| zener diodes & rectifier diodes | mozikluv | Datasheet/Parts Requests | 2 | 16th September 2003 05:17 AM |
