+ Reply to Thread
Page 2 of 4
First 1 2 3 4 Last
Results 16 to 30 of 60
Thread: convert 220 AC to 3.6 VDC for lighting LED
  1. #16
    ecerfoglio Newbie
    Join Date
    Jul 2007
    Location
    Buenos Aires
    Posts
    177
    Quote Originally Posted by DMW
    Actually ......this is called reluctance rather than resistance because unlike resistance no power is dissipated in the capacitor.
    The Formula shown below determines the reluctance for a capacitance.
    Xc = 1/(2 * Pi * F * C)
    Xc = 1/(2*Pi*50*220nF)
    Xc = 14.4Kohm
    It's not reluctance but reactance.
    Both capacitors (Xc = 1 / (2 pi F C) and inductors (XL = 2 pi F L) have reactance. If you have an inductor and a capacitor in series the total reactance is de difference of them (Total X = XL - Xc)
    (The Reluctance is used in magnetic circuits)
    E Cerfoglio
    Buenos Aires
    Argentina
  2. #17
    DMW
    DMW is offline
    DMW Newbie
    Join Date
    Dec 2007
    Posts
    67
    ops yes i did know its reactants, I must of chosen the wrong one without thinking when dong spell check.
    edit
    I thought the total reactants of L/C was:
    square-root(Xc^2 + XL^2)
    Like Pythagoras theorem
    Or is that something else?
  3. #18
    ecerfoglio Newbie
    Join Date
    Jul 2007
    Location
    Buenos Aires
    Posts
    177
    edit
    Not, if you have a capacitor, an inductor and a resistor in series, then the impedance (Z) is
    Z = square-root(R^2 + (XL - Xc)^2)
    (or, using complex numbers, Z = R + j (XL - XC), where j is the square root of minus one)
    E Cerfoglio
    Buenos Aires
    Argentina
  4. #19
    DMW
    DMW is offline
    DMW Newbie
    Join Date
    Dec 2007
    Posts
    67
    Of course its in converting from rectangular to polar form.
  5. #20
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    937
    Default 230 Volts LED
    I have posted a schema a while back under 230 Volts LED with photo's.
    I have used this succesfully for nearly 20 years in industrial metering and indication circuits on power systems 230 / 240 Volts 50 Hz.
    D1 - 1N4007
    D2 - 1N4148, 1N914
    D3 - High efficiency LED
    R1 - R2 - 33 or 39 khm: 1 Watt resistor
    D1 assisits in reducing the power dissipation in R1 and R2 to 0.7.
    To reduce flicker if it bothers you use a bridge rectifier as already suggested.
    Please don't sent me private messages, I will not answer them.
    The questions asked can be discussed in the open forums.
    http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
  6. #21
    wayne2056 Newbie
    Join Date
    Sep 2008
    Posts
    11
    Default My Bad
    Quote Originally Posted by DMW View Post
    Actually that's not true I believe [for the first diagram]
    The 10M has little effect on the circuit, you see capacitors have a resistance to low frequencies, this is called reluctance rather than resistance because unlike resistance no power is dissipated in the capacitor.
    Xc = 14.4Kohm
    This is in parallel with 10M, because 10M is so high it makes little difference to the resistance.
    14.4K + 1K because its in series with the 1K resistor is
    15.4K
    current = 230 / 15.4 = 15mA
    Seems a little low to me.
    Edit:Whops I was using RMS value
    root(2) * 230 = 425V
    425 / 15400 = 21mA.
    Thats better
    Thanks DMW... I need to relearn what Xc is and how to apply it.
    Wayne2056
  7. #22
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,187
    Another option is to just use a bipolar LED which will produce no flicker and won't require a reverse parallel diode.
    if I know the answer.
  8. #23
    Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent Ubergeek63 Excellent
    Join Date
    Apr 2008
    Posts
    1,275
    Quote Originally Posted by Hero999 View Post
    better yet just stick the LED in a diode bridge if its a HB, Only junk die come in bipolar LEDs until you get to the expensive stuff that they proceed to charge even more for.
  9. #24
    mamun2a Newbie
    Join Date
    Nov 2006
    Location
    Dhak, Bangladesh
    Posts
    89
    thanks all to help me with suggestions.
    i'm fully stupid about the hitek laws.
    but i impressed with rodalco's idea.
    dear rodalco, what difference on effecincy LED and general LED?
    mamun2a, dhaka, BD
    'if u cant beat him then join him' I always say...
  10. #25
    Flarup Newbie
    Join Date
    Nov 2008
    Posts
    2
    Many years ago I also used this principle to make a led light up just for signalling, no harm in that.
    But today my interest is on LED lightning, thus there may be a legal harm. As I understood the effect of the capacitor it causes a phase shift (sorry if I use wrong terms, im a bit rusty on this)
    Now the effect of this phase shift is that voltage & current does not follow each other and thus no components are overloaded.
    But that kind of circuits may also cheat the power meter from the electricity company, and thus they are illegal. The same effect is seen on neon tubes where a capacitor is required for the metering to be accurate.
    Also a similar effect is seen from switchmode power supplies in eg computers, where the cheap power meters cannot measure the power consumption of a computer. I don't know why the power meter from the electricity company can handle computers though.
    But besides all that, what is the more power effective, a switchmode power supply or a capacitor? The switchmode can do 80-90% efficiency today. But it is quite expensive. Cheap transformer based power supplies do not go above 50% efficiency.
    Thus using capasitors could be very interesting. Especially now when all the Christmas lightning comes up again.
  11. #26
    Shehzad Newbie
    Join Date
    Nov 2008
    Posts
    2
    Default Please Help
    What if i need to have 4 LEDs in series or in parallel ??
  12. #27
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,881
    With one 2V LED operating from 220V then its current is 21.8mA with a 10k ohm resistor.
    With four 2V LEDs in series operating from 220V and with a 10k ohm resistor the current will be 21.2mA and they will look the same as the one LED.
    LEDs should not be connected in parallel. They are not exactly the same so one will hog a lot of the total current and burn out. Then the remaining LEDs will have more current and they will quickly burn out.
  13. #28
    Shehzad Newbie
    Join Date
    Nov 2008
    Posts
    2
    you mean to say that, if i connect 4 LEDs in series using the same circuit there would be no change required in circuit ?
    the glow of each LED will be same(as when a single LED was used) or will 1/4
  14. #29
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,881
    I showed the calculation for the current in one LED to be almost the same as the current in 4 LEDs because the voltage is so high that there is very little difference in the current. Then there is very little difference in the brightness.
    If each LED is 2V and if the supply is only 10V then one LED will have a current of 20.5mA with a resistor of 390 ohms and four 2V LEDs in series and with a 390 ohm resistor will have a current of 5.1mA (one-quarter of the current for one).
  15. #30
    Insider Newbie
    Join Date
    Sep 2008
    Location
    Lahore, Pakistan
    Posts
    5
    Default Emergency LED Light with a Battery
    I have build a lot of lights of this kind using a 2.2mfd 400VAC capacitor in series with a bridge rectifier, and it has got ample power to trickle charge the Battery which is 6V 7AH, and it can sustain 104 Leds (5mm White LED) for 4 hours.
    some people might think this a hoax, but they dont live in a country which has got 14 hours power outages every 24 hours. So I think I am more desperate than most of you to make the dream come true with a Solar Cell for a Light without mains supply.
    Insider
    Kinetics Automation
    fahimbaig2@gmail.com
+ Reply to Thread
Page 2 of 4
First 1 2 3 4 Last
  1. need help...
    By imisendo_4036 in forum Micro Controllers
    Latest: 20th February 2008, 01:15 AM
Tags for this Thread
