Hi Im learning to test resistors.How can I tell wich color is the first digit?Cant tell whats top or bottom
The last band (tolerance) is often gold or silver.
i cheat, and use a multi meter to test the resistance!!!
http://consolehack.forummotion.com |
After you've worked with electronics for a time, you'll begin to recognize the standard values of parts. There are 24 standard values per decade for resistors and when what you think are the first two digits look "funny", you'll quickly start from the other end to find a more familiar value. The 24 standard values for 5% resistors are 10, 11, 12, 13, 15, 16, 18, 20, 22, 24, 27, 30, 33, 36, 39, 43, 47, 51, 56, 62, 68, 75, 82 and 91. That is, you'll find as a standard value 0.62, 6.2, 62, 620, 6.2K, 62K, 620K, 6.2M and 62M ohms, although the first and last won't be very common, especially the 62M. 10% standard values use every other of the 5% values, 20% standard values use every other of the 10% values, always beginning with 10.
Dean
Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. |
With these, you can approximate values or use them in series and parallel.
If you aren't afraid of life then you aren't paying close enough attention. |
theres 3 resistors im doing something wrong on or they are bad.all 3 are the same,br-bl-rd-gld...i have 10*100=1000 with a tolerance of 5%(50) these resistors are on 3 totally diff parts of the same board..2 of them are reading 799 wich im confused to wich way to lean..good or bad.. my reading should be from 950 to 1050..the third one really got me.its 01.2..
im using a fluke to test. when a res goes bad is the reading tottaly off or can it be a lil bit off the tolarence and still not work..or is it open.. what causes a res to go bad is there visual evidince when it goes bad when i test the ends is it ok to test the sodered part if my probe cant fit between the bottom of the res and the board and is it normal for a res to go bad
you guys are great excuse my bad typing and spelling im not that much of a comp guy |
All your readings are low....I suspect that you are reading the 1000 To measure a resistor you should disconect at least one terminal from the rest of the circuit.
E Cerfoglio Buenos Aires Argentina |
You're much better off stocking a few of all the 5% standard values rather than kludging together values from what you can find laying around. Series and parallel combos can push power and voltage ratings if you're not careful. Dean
(permalink) | ||
I can't sympathize with you on your need to travel to find parts. The nearest electronics store that's worth the trip for me is 3 hours away. There's a Radio Shack in the nearest town 12 miles away, but Radio Shack in the U.S. is as worthless as the mammary glands on a boar as they carry very few piece parts these days. They're only good for cell phones, overpriced computers and other consumer products. Dean
(permalink) | ||||
Resistor value chart attached, hope it helps
Cheers, Rodalco
There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. |
Rodalco,
Re: The chart's 6 band resistor colour code What is the sixth band used for? The chart does not say. I think there is an error too. I see the 6 band example as 650K, not 620K as stated. Bob |
http://www.google.com/search?client=...utf-8&oe=utf-8
Generally the most popular values are multiples of 10, followed closely by 47 and 22. This is because 10, 22 and 47 form the E3 series which is still very common even though 50% tollerence resitors probably went out of fashion back in the 1890s. Generally when stocking an inventory I resomend a set of the E24 values, plus more of the E12 values, even more of the E6 values and loads of the E3 values. Generally as the E number goes up, the values become less common and as the E number goes down they become more common.
| Led Resistors reach 110C!! | dons21 | General Electronics Chat | 26 | 20th January 2008 03:13 AM |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 27th August 2007 11:05 PM |
| 7447 with resistors | Overclocked | General Electronics Chat | 5 | 27th January 2007 12:30 PM |
| Resistors | Marks256 | General Electronics Chat | 52 | 3rd August 2006 01:00 AM |
| Electric Heater using 330 Ohm Resistors | Electric Rain | Electronic Projects Design/Ideas/Reviews | 20 | 14th January 2005 08:53 PM |
