Old 22nd February 2008, 03:16 AM   (permalink)
Default switch input to paralel port
I am having this problem.
When i click the switch (mechanical switch)
instead of getting this:
00000000001111111111
I get this:
00000101010101111111
when I successively read changes to bit 5 (mask 32)(pin 12) of the
status port(base+1) of the parallel port. ( LPT1: base=378h)
I dont think anything is ocsilating.
I am guessing that change of voltage on the switch is too slow
and that when it is around 1.7x V , 50Hz interference from the power grid
gets amplified at the base of an input transistor.
I didnt know that the capacitance of a switch is so high, or is it something
else?
I actualy want to measure RPM of a brushless DC motor so when I connect
a hall generator to the port I dont get this problem
(I am guessing because there is a schmitt trigger in it)
but this is only me testing with a magnet in my hand.
I am wondering how the voltage is chaneing when the motor is spinning.
So should I use the schmitt trigger at the input or the interference can be
filtered out diferently?
And I am also very puzzled that a switch is so slow.
Many thanks.
vlad777 is offline
Old 22nd February 2008, 12:55 PM   (permalink)
Have you not heard of 'contact bounce'?.
Old 22nd February 2008, 05:31 PM   (permalink)
Nop. But something like that is what first came to my mind.
I didnt know how to call it so I didnt search it on the net.
Because of this I also tried to use a potentiometer as an input.
When I turn the thing fast enough I get less glitches maybe even
a clean transition.But when I turn the thing slovely until I hit
special voltage level then I get continualy changeing input.
This also happens when I touch the unconected base of the
transistor that is conected to the port.
(When I connect the base to the ground with a resistor then nothing
happens when i touch it)
I am guessing this is because of interference.
How do you fight this?
Anyway on wikipedia I saw a circuit that might satisfie me.
Thanks.
vlad777 is offline
Old 22nd February 2008, 06:04 PM   (permalink)
Thanks.
Once you knew what it was called, it's easy to find information on it!
Output = Input - Problems adamthole Micro Controllers 20 24th April 2007 05:09 AM
Reed Switch kid Datasheet/Parts Requests 1 18th February 2006 02:52 AM
1 port with multi input and output function yce_kelvin Micro Controllers 1 2nd July 2004 04:06 PM
Help with AND gate Switching TheFox Electronic Projects Design/Ideas/Reviews 4 18th September 2002 06:43 PM
