Old 17th February 2008, 09:23 PM   (permalink)
Default Footprint creativity/IC-change
Hi Guys
I just submitted a request for a pin-compatible replacement for the 74HC7541 over in the datasheet-forum, but now it occurs to me that really I need a creative piece of advice.
The thing is, that I have eight analogue signals which are supposed to trigger an interrupt on my AVR-processor. They are, however, a bit weak, so on my prototype PCB, I buffered each of them with a 74HC7541 gate.
I think it would be better to use an opamp configured as a comparator, but I have already the 2x10 pin DIP footprint from the '7541. Any good (creative) ideas how to replace that IC with op-amps for the eight signals?
Need info? Ask away and I'll answer.
Analogue in:
Low signal = 0.2V
High signal = (to be) ~1V
Digital(ish) out:
Low signal = 0-0.1V
High signal = 3-5V
Thanks in advance.
/Pax
Pax Writer is offline   Reply With Quote
Old 18th February 2008, 04:47 AM   (permalink)
Why can't you use the 74HC7541? You could sub a 74HC7245 if you tied pin 1 high. You won't find an octal opamp that you could just put in place of the 74HC7541. You'll need to redo your proto board. A couple of 14 pin LM339's would work but would take up a little more PCB room.
BTW, you can get the 74HC7541 at digikey:
http://search.digikey.com/scripts/Dk...7541&x=17&y=11
kchriste is online now   Reply With Quote
Old 18th February 2008, 09:54 PM   (permalink)
Hi kchriste
Thanks for your reply. Well, the reason I prefer not to use it is, that my local component-pushers don't carry it, which I was incautious enough not to check before designing the board.
I'll take a look at the 74HC7245, but judging from its name, it'll be a longshot.
As for the redesign, there's no doubt that it will have to be redesigned anyway, but for the first couple of protos, I'll make do with this.
Note: I actually found two 74HC7541s in the back of my component-closet, and they work better than I thought. Too bad they are so hard to come by in Denmark. Maybe I'll just have to accept the shipping costs from digikey...
Thanks again for your detailed and thought-through answer.
Old 19th February 2008, 04:06 AM   (permalink)
Digikey can be a bit steep on shipping for non-US customers...in fact, its because of that I have never ordered from them, just get a few friends in the US to tag on my stuff to their order then ship me the components via airmail.
You have some other options though for copmonents:
Farnell (farnell.com). - minimum order (20UKP), but they have almost everything.
RS (rswww.com) - slightly more expensive, but worth it. Pro's.
Ebay. - the 'ol favourite. You can get loads of components from all over the world...and for IC's shipping is genenrally dirt-cheap. Plenty of 'ebay shops' that stock thousands of IC's. - not reliable though if you need a specific part.
The above three are my main distributors, apart from a couple who only deal within the UK. I'm sure farnell will stock it though.
Blueteeth
Inconsistency is the key to flexibility!
Blueteeth is offline   Reply With Quote
Old 19th February 2008, 05:17 PM   (permalink)
Well, why couldn't you build a sub-cct. that plugs into your 2x10 socket?
BeeBop is online now   Reply With Quote
Old 19th February 2008, 06:17 PM   (permalink)
@Blueteeth: Thanks for the tip. Maybe I'll have a look at Ebay. RS and Farnell I know, and I generally think they're good suppliers.
@BeeBop: I have a feeling this will be a semi-stupid question, but what is a sub-cct?
Old 19th February 2008, 08:03 PM   (permalink)
'cct' is shorthand for 'circuit', so 'sub-circuit'. What he means is that you don't need a component of the same size/shape as the original; if you needed to, you could build a circuit on another piece of board, give it the same inputs and outputs as the original IC, and plug the new sub-circuit into the socket or holes intended for the original part.
I've seen people do this for various reasons: to replace an op-amp with a different one with a different pinout; to do something like what you're trying to do, etc.
Torben
Torben is online now   Reply With Quote
Old 21st February 2008, 02:18 AM   (permalink)
Thanks,
Torben, that is exactly what I meant.
Old 21st February 2008, 03:38 AM   (permalink)
Torben
When I worked in San Jose, we called those "daughter board"s. Those would attach to a (example) servo board, and the servo would plug into the "backplane". Odd that nothing was called the motherboard! The backplane was mounted in a Unibody, and the Unibody was mounted in the final product, a huge 10' X10' X 5' wafer inspection machine.
Bob
Bob Scott is offline   Reply With Quote
Old 21st February 2008, 04:05 AM   (permalink)
Bob
Cool. If I'd known when entering university the difference between "computer science" and "computer engineering", I would have gone into the CE line of study instead.
Pax, just to clarify: I didn't mean that "sub-circuit" always means what BeeBop and I said before, just that it's a term that you could use to mean that. It can also mean any smaller portion of a larger circuit. I think you know that but I just wanted to clear it up in case.
Cheers,
Torben
Old 22nd February 2008, 12:16 PM   (permalink)
Hey all of you
Thank you for the input. Incredibly, I didn't consider making a sub-cct (new word in my vocabulary, yay!), but that's an excellent idea for my prototypes.
Have a nice one!
*off to solder*
Best regards.
Please help me in writing code abdosat2000 Micro Controllers 9 5th June 2007 01:40 PM
measuring transconductance(gm) walters General Electronics Chat 24 6th February 2006 08:49 AM
PCB footprint for serial EEPROM battpower Electronic Projects Design/Ideas/Reviews 2 26th January 2005 12:30 AM
12f629 - int on pin change, and tmr0 not working together... SnM Micro Controllers 7 16th November 2004 07:30 PM
Digital Clock Color Change JaTaN General Electronics Chat 1 25th August 2003 01:31 AM
