Old 14th February 2008, 11:38 PM   #1
Default problems measuring capacitors
I need help measuring capacitors.
I use a "Almost all digital Electronics" L/C meter to check the values of capacitors.
I recently ordered some tantalum 6.8mF capacitors which give me a value of about 0.2 mF when measured.
A second batch I got gave similar values.
Electrolytic capacitors are way off.
I wonder if rather than bad capacitors I do have a lack of understanding about the nature of capacitors, and which ones should check out ok and which ones do not.
Any clarification is appreciated
Uwe
Othello is offline
Old 15th February 2008, 12:37 AM   #2
Do you mean 6.8 microfarads, or 6.8 millifarads? In either case, the AADE web site says that the maximum range on the LC meter is 1.5 microfarads (uF).
Ron
Roff is online now
Old 15th February 2008, 12:48 AM   #3
and non-polarized. John
jpanhalt is offline
Old 15th February 2008, 12:49 AM   #4
Good point. I missed that.
Ron
Roff is online now
Old 15th February 2008, 01:49 AM   #5
Default c-meter
Hi Uwe,
look up http:///www.elektor.de. Search "Messen und Testen". From the list select L-C-T-Messer.
This device measures temperatures in the range from -55 to 125deg/C with 0.5deg resolution, inductances in the range from 100nH to 100mH and capacitances in the range of 1pF to 160.000uF.
The MCU used is an Atmel ATMEga48.
The built in C-meters in DMMs do not consider the ESR of a cap, so the result will always be miles off. They are just good enough to measure if the cap has a short.
Hans
Boncuk is offline
Old 15th February 2008, 11:55 AM   #6
I wonder why people are reluctant to use mF, but 2200uF, 4700uF instead of 2.2mF and 4.7mF.
But we have no problem using mH, mA, milliOhm, mV. Perhaps it is easily confused with nF during printing or photocopying.
I guest the "2200" or "4700" also gives the impression that it is big, which it is in physical size.
L.Chung
eblc1388 is offline
Old 15th February 2008, 12:37 PM   #7
Because it causes confusion, with some people incorrectly using 'm' for micro, using a 'u' for the greek letter mu makes far more sense.
Bear in mind it's also common to say 1000pF or even 22,000pF rather than use nF.
Old 15th February 2008, 06:54 PM   #8
nF seems to be a more recently used measurement . Older schematics seem to aviod it and only use pF and µF so 1nF would be written as 1000pF or 0.001µF.
if I know the answer.
Hero999 is offline
Old 15th February 2008, 07:11 PM   #9
That's funny, the older schematics I remember all used uufd (as in micromicrofarad)
Nano just seems to be a relatively recent (last 25 years) multiplier. We also used to use mu, which was written with a "mu" instead of a "u" and pronounced "millimicron," in wavelength measurements to represent what today is nm. John
jpanhalt is offline
capacitors, measuring, problems
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 03:44 PM
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 28th August 2007 12:06 AM
Giant Capacitors. Where do I find them? Halogrunt1234 General Electronics Chat 17 6th October 2005 02:20 AM
Most suitable type of capacitors to solve noise problems? Haru General Electronics Chat 3 9th May 2005 11:58 PM
Current or power limits for capacitors stevez General Electronics Chat 4 21st May 2003 12:08 PM
