Old 13th February 2008, 10:14 AM   #1
Default Induction heater - Aluminium
Hi all,
I was build 200khz half bridge inverter (cca 1kW), which have variable matching inductance, tank capacitor and work coil (10mm Cu) + lot of snubbers.So for iron(magnetic) stuff it works ok, (it heat iron very well at resonance), but I have problem with aluminium. It wont heat it (it become only worm 50°C), and inverter have big problems with "ringing" and self destruction .
I suppose that 1kW power is enough for melt some small piece of material but there is happening somethnig and I can't findout what...
I know that aluminium is highly conductiv, and it do not have magnetic characteristics like iron (probabbly is problem there).
Thus someone know which frequency to use for melting aluminium with inductive heater?
Thanks in advance,
Flash
Flash_Cro is offline
Old 13th February 2008, 10:32 AM   #2
No. The problem is not magnetic property but the first part of your statement. Induction furnace works by inducing current in the material to be heated. Aluminum is highly conductive and generate very little heat from eddy current loss.
Do you know of any induction furnace for copper?
L.Chung
eblc1388 is offline
Old 13th February 2008, 10:11 PM   #3
You are right eblc1388 So that means that for aluminium I should use low frequency inverter which can produce more power, becouse I need bigger eddy currents. (I was forget on Lenz's law .....)
Regards,
Old 15th February 2008, 04:38 PM   #4
Alter the impedance matching network?
You want to effectively lower the output voltage and increase the current to melt the aluminium.
if I know the answer.
Hero999 is offline
Old 15th February 2008, 09:53 PM   #5
Well I was alter matching network, and on resonance I can get big currents on low voltage, but on scope I see (parasit osc.) that inverter is close to explode...
Inverter voltage and sine shape (on scope) is same with or without aluminium insde of coil on 200 kHz, and inverter likes to go in oscilations which on the end kill mosfet's.
I will try with low frequency about 5-20 kHz. On this frequencys I can easilyer control mosfet's and osciltions, or even use igbt's.
Regards,
Old 15th February 2008, 10:16 PM   #6
If you lower the frequency, you'll have to add more turns to the coil and use a larger tuning capacitor; there might be other modifications that you'll also have to make but we can't really advise you as we don't have access to the schematic.
Hero999 is offline
Old 16th February 2008, 01:38 PM   #7
Here is schematic:
I know that I will must change components, that is not problem only thing is which frequency is the best for Al melting.
Regards,
Old 16th February 2008, 02:29 PM   #8
I can't say I'm the best person to advise you on this as I haven't had any experiance with this sort of thing.
All I can say is that Lm, Lx and Ct probably need increasing to reduce the resonant frequency. but you probably already knew that.
Hero999 is offline
Old 20th February 2008, 09:02 AM   #9
i don't have much knowlege about induction furnace, but i have seen one used for aluminium. it was a selfmade furnace and they used a steel crucible instead of the carbon type. Please seek additional information on the details before you try it.
shirazmacuff is offline
Old 10th May 2009, 03:33 AM   #10
I have also made an Indcution heating system but mine does not work(it blows out the MOSFETs), I am using MOSFETs and the LCLCR has a matching as were given in the Nichei diagram. help to get out.
asifali is offline
aluminium, heater, induction
Miniature Induction Heater Project - Help needed beachracer Electronic Projects Design/Ideas/Reviews 2 12th April 2009 01:31 AM
Need help for induction cooker/ heater muki55 Electronic Projects Design/Ideas/Reviews 9 27th March 2009 02:46 PM
RF Induction Heater Circuits Diagram. pgpsvit Electronic Projects Design/Ideas/Reviews 3 15th December 2007 11:55 AM
concerning charecteristics of resistive heater Ramesh Babu Adari Feedback/Comments 0 25th February 2004 02:39 PM
Diff between Slip Ring and Squirrel Cage Induction Motor avinsinanan General Electronics Chat 10 23rd February 2004 11:55 PM
