If anyone out ther is interested in controlling a unipolar stepper motor via the parallel port on your pc and also uses Qbasic then copy the code below into a qbasic file and have at it. The program will prompt the user for mode of operation eg. single coil excitation mode or double coil excitation mode, direction and how many clock cycles to make the delay. A good value for my "VERY ANCIENT" pentium 133mhz pc is anywhere from 45 to however long you want the delay between coil energization to be. below 45 clock cycles the stepper motor likes to malfuntion. I am using parallel printer sentronics? connector. Modify the program to your liking. Sorry I did not include comments.
pins #2 for coil 1 #3 for coil 2 #4 for coil 3 #5 for coil 4 #18(can be any ground) for ground. I am also using a uln2803 darlington transistor array to drive the motor. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;; ;Written by Sam Bixler ; ;Date 03-10-03 ; ;For controlling a unipolar stepper motor via a parallel port ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;; CLS VarMode = 0 VarRot = 0 VarRev = 0 VarDelay = 0 int1 = 0 Main: CLS OUT 888, 0 DO UNTIL INKEY$ <> "" PRINT "Enter the number of revolutions" INPUT VarRev VarRev = VarRev * 50 PRINT "Enter the Mode of operation" PRINT " 1 for single coil excitation" PRINT " 2 for double coil excitation" INPUT VarMode PRINT "Enter the number of delay cycles" INPUT VarDelay PRINT "Enter the direction of rotation" PRINT "5 for CW 7 for CCW" INPUT VarRot VarMode = VarRot + VarMode IF VarMode = 6 THEN GOTO ScCW: IF VarMode = 7 THEN GOTO DcCw: IF VarMode = 8 THEN GOTO ScCcw: IF VarMode = 9 THEN GOTO DcCcw: ELSE GOTO nd: LOOP ScCW: DO GOSUB Step1: GOSUB Step2: GOSUB Step3: GOSUB Step4: VarRev = VarRev - 1 IF VarRev = 0 THEN GOTO Main: LOOP ScCcw: DO GOSUB Step4: GOSUB Step3: GOSUB Step2: GOSUB Step1: VarRev = VarRev - 1 IF VarRev = 0 THEN GOTO Main: LOOP DcCw: DO GOSUB Step5: GOSUB Step6: GOSUB Step7: GOSUB Step8: VarRev = VarRev - 1 IF VarRev = 0 THEN GOTO Main: LOOP DcCcw: DO GOSUB Step8: GOSUB Step7: GOSUB Step6: GOSUB Step5: VarRev = VarRev - 1 IF VarRev = 0 THEN GOTO Main: LOOP Step1: OUT 888, 0 DO OUT 888, 1 IF int1 = VarDelay THEN RETURN int1 = int1 + 1 LOOP Step2: OUT 888, 0 DO OUT 888, 2 IF int1 = 0 THEN RETURN int1 = int1 - 1 LOOP Step3: OUT 888, 0 DO OUT 888, 4 IF int1 = VarDelay THEN RETURN int1 = int1 + 1 LOOP Step4: OUT 888, 0 DO OUT 888, 8 IF int1 = 0 THEN RETURN int1 = int1 - 1 LOOP Step5: OUT 888, 0 DO OUT 888, 3 IF int2 = VarDelay THEN RETURN int2 = int2 + 1 LOOP Step6: OUT 888, 0 DO OUT 888, 6 IF int2 = 0 THEN RETURN int2 = int2 - 1 LOOP Step7: OUT 888, 0 DO OUT 888, 12 IF int2 = VarRev THEN RETURN int2 = int2 + 1 LOOP Step8: OUT 888, 0 DO OUT 888, 9 IF int2 = 0 THEN RETURN int2 = int2 - 1 LOOP nd: OUT 888, 0
\"Genius is 1% inspiration and 99% perspiration.\" Thomas Alva Edison |
good one Electrogeek.
I've connected leds to my outputs and: Single coil excitation , colockwise and counter-clockwise works perfect. Double coil excitation apears not to work properly on my computer(p2 350mHz). one of the leds,(line out) only energises for a very very short time compared to the others. how many line outs do you nead for double excitation? to see what i'm talking about, connect leds to line outs, and run double excitation, with delays of about 10000(very slow). you should see one of the lines flash on/off very quickly. And use super bright leds. well done. good program! For what project are you going to use the stepper for? |
