Old 8th February 2008, 04:36 AM   (permalink)
Default how warm/hot is safe for a transformer
hi i have a aplication that becuase of the power draw warms up the transformer
the transformer is roughly 50 degree Celcius in use with an ambient temp of 27 degrees Celcius no airflow
can this be seen as acseptable or do i have to increase the transformer
please advice
Robert-Jan
rjvh is offline
Old 8th February 2008, 04:51 AM   (permalink)
Sounds okay. I assume a transformer can handle much more heat than a power MOSFET and a 20 degree rise is pretty darn good for a power MOSFET (at least in my circuits anyways).
dknguyen is offline
Transformers vary. But 23 C rise seems pretty reasonable to me.
You do waste a bit of power in heating the transformer, but most systems don't care.
mneary is offline
Old 8th February 2008, 05:03 AM   (permalink)
I have an isolation transformer that gets so hot you can't keep your finger on it, even with no load. IIRC, the temperature was about 60C, a 30-35C rise. I called the mfr and spoke to an engineer, who said it was normal. Pissed me off, but it works, so what the hey.
My assumption is that the primary inductance is low, which saves on copper. This is why it was cheap (literally). Low inductance causes higher magnetizing current, with accompanying I^2*R loss.
Ron
Roff is offline
Old 8th February 2008, 05:04 AM   (permalink)
Originally Posted by Roff
I have an isolation transformer that gets so hot you can't keep your finger on it, even with no load. IIRC, the temperature was about 60C. I called the mfr and spoke to an engineer, who said it was normal. Pissed me off, but it works, so what the hey.
Lol..
"It burns when I touch it!"
"It's supposed to. THat's normal."
dknguyen is offline
Old 8th February 2008, 05:06 AM   (permalink)
Originally Posted by dknguyen
Lol..
"Don't worry, tHat's normal."
He stopped just short of saying "tough shit, sucker!".
Ron
Roff is offline
Old 8th February 2008, 05:10 AM   (permalink)
thanks for the conformation that everything is OK
Robert-Jan
rjvh is offline
Old 8th February 2008, 05:11 AM   (permalink)
Yeh, for the motor circuit I'm building I'm predicting the FET will be running at 130C room temperature. They are supposed to be able to handle 150C though, and I over assumed an ambient temperature of 50C like I usually do. I figure it should maybe be okay since full-load is stall.
I wish I could get a 20C rise out of that lol.
dknguyen is offline
Old 8th February 2008, 09:04 AM   (permalink)
Even a poor transformer will take a lot more primary current when loaded than when not. The I^2*R loss will be far bigger when loaded, so if that was what was making it hot when unloaded, it will burn out when loaded.
It is the iron loss that is causing the unloaded heating. That is due to not enough iron, so magnetic field is too intense, driving the core into saturation. With cheap iron, that is also where there is hysterysis, so there is energy loss as the iron is "permanently" magnetised forward and backwards, 50 or 60 times a second.
There is also eddy current loss, if the laminations aren't done correctly.
Diver300 is offline
Old 8th February 2008, 02:09 PM   (permalink)
The manufacturer should be able to provide an indication of the limits and conditions that apply to their product. While at a basic level transformers might be similar a simple thing like insulation on the wire could affect allowable temperature rise. As Ron indicated, his transformer runs hot and the manufacturer said it's ok. The manufacturer might have constructed the transformer so that it will provide reliable service for a long time under those conditions - or they might have overstated their specifications. That's a game that's played constantly.
stevez
stevez is offline
Old 8th February 2008, 10:49 PM   (permalink)
I have a Chinese Ni-MH battery and a Chinese AC-DC charging adapter for it.
Boy oh boy oh boy do they get hot, very very hot.
I threw out the 9V/200mA adapter that was about 22VDC without a load and made my own charger. Luckily the battery didn't explode.
audioguru is offline
Transformer Problems? MsStateDawg Electronic Projects Design/Ideas/Reviews 15 2nd November 2007 11:17 PM
Safe Project robin1987 General Electronics Chat 2 6th August 2007 03:12 PM
Problems selecting a PCB Transformer NewcastleSAR Datasheet/Parts Requests 31 4th January 2007 08:16 PM
Rewinding Transformer Gregory Electronic Projects Design/Ideas/Reviews 2 22nd May 2006 11:36 AM
Differential transformer how to measure this signal sardineta Electronic Projects Design/Ideas/Reviews 18 7th October 2004 03:31 PM
