Old 6th February 2008, 03:54 AM   (permalink)
Default 555 timer flashing LED circuit
Can someone please help me out here? I am trying to build a flashing LED using an ultra bright LED. I am getting conflicting results from various online calculators.
I am using an NE555P and trying to drive an ultra bright 3.4V 20ma led from a Vcc of 12vdc. I want the led to flash at a rate of approx 600 times a minute to emulate machine gun fire. Will the below circuit with the values of RA 56K, RB 56K, C 0.001uF and LED resistor 470R work ?
I would also like to be able to drive 12v solenoid from the timer with the option to activate the solenoid at the same time as the led and also opposite timing to the led.
matt_hau is offline
Old 6th February 2008, 05:57 AM   (permalink)
What are your conflicting results?
mneary is offline
Old 6th February 2008, 06:07 AM   (permalink)
Default 555 timer
I am just not sure if I am reading the values correctly on the calculators, some are in farads or micro farads and i have done the conversion on a spreadsheet to double check,
When i built the circuit initially with RA and RB using 500ohm and 100uF capacitor the led came on and stayed on. I recheck it on another calculator and I get 50K and .001 uF.
Confusion is setting in.
matt_hau is offline
Old 6th February 2008, 06:37 AM   (permalink)
500R and 100uF gives a an output of maybe 20 Hz, which should flicker or maybe even appear to stay on at 1/2 brightness. Try 1.5k ohm.
If you want more sensible results try starting the calculators with 0.1 uF.
Most solenoids will have a hard time reacting to 10 pulses per second.
mneary is offline
Old 6th February 2008, 06:57 AM   (permalink)
I want to achieve this.
http://www.zex.com/Base/Video/ZexMac...rgeKitWEB1.wmv
matt_hau is offline
Old 6th February 2008, 07:22 PM   (permalink)
It may appear that the steam is being interrupted at the same rate as the LED, but I think it only looks that way because of the strobe effect.
Any clarity on the calculations?
mneary is offline
Old 7th February 2008, 12:54 AM   (permalink)
The gas is being interrupted giving the cracking sound,
I have tried to slow down the frequency of the flash but the led still stays on constantly. I did notice that when i touched the underside of the 555 the light went out and the when i touch again it comes back on. There is no bad solders on it so I am thinking my finger is causing a discharge of the cap causing the volts to go low therefore turning of the LED??????
Some other diagrams I have seen show a cap from pin 2 to earth as well as jumped across to pin 6 or a 0.01uF cap from pin 5 to earth. Should I be doing this?
matt_hau is offline
Old 7th February 2008, 06:43 PM   (permalink)
In your original post, pin 2 has a label "To pin 6". That indicates that you should connect those pins together.
In the "clasical" astable (oscilator) 555 configuration, pin 2 and 6 should be connected together - The timing capacitor goes from the junction of pins 2 and 6 to ground, there is one timing resistor between pin 7 and the junction of pins 2 and 6 and another timing resistor from pin 7 to +V.
The circuit will work without the 0.01uF capacitor between pin 5 and ground, but it is good practice to use it, as well as a 0.1uF power supply decoupling capacitor between pin 8 and ground.
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is offline
Old 7th February 2008, 09:33 PM   (permalink)
If the led's flashing at 600 times per minute (10 times per second) I wouldn't have thought you'd notice, won't it just look like it's flickering slightly?
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 8th February 2008, 02:35 AM   (permalink)
Agreed, I tried to slow down to 4 times per second but had the same result. New set up to try out will be Ra 1K Rb 91K and C1 1uF, That should give me a frequency of 7.88Hz with a 50% duty cycle.
matt_hau is offline
Old 8th February 2008, 02:45 AM   (permalink)
Have you connected pin 2 to pin 6 as directed?
All those who believe in psycho kinesis, raise my hand.
AllVol is offline
Old 8th February 2008, 02:50 AM   (permalink)
Yes, had done form the start. I have not done the caps on pin 5 and 8 yet though.
matt_hau is offline
Old 8th February 2008, 06:33 AM   (permalink)
Just in case if your not absolutely stumped yet:
http://www.kpsec.freeuk.com/projects/flashl.htm
It is strip board so it is connecting horizontally.
Krumlink is offline
Old 8th February 2008, 02:49 PM   (permalink)
Thanks for the link it looks good and is pretty much what I have already got. I have just read though that with DC voltage I should run a decoupling capacitor. I will give the decoupling a go tomorrow and try the bigger RB resistor to slow down the frequency as per the link.
very frustrating but I am learning lots.
matt_hau is offline
Old 11th February 2008, 12:48 AM   (permalink)
I finally got it!! RA 1,000K RB 91,000k C 1nF. It flashes perfectly at about 7 cycles per second and I have even hooked it to a sugarcube relay (any risks in that?)
I found one site that suggested the minimum RA should be 3K and worked from there to achieve the desired flash rate.
matt_hau is offline
Complex (Sort of) timer circuit using relays... Electric Rain Electronic Projects Design/Ideas/Reviews 15 8th September 2008 01:45 PM
One Shot Timer Circuit Gary Houston Electronic Projects Design/Ideas/Reviews 21 28th January 2007 02:48 AM
Help, Need a non digital timer circuit. (Relays man) BART Electronic Projects Design/Ideas/Reviews 10 9th November 2006 09:39 PM
led flashing circuit andrew2022 Electronic Projects Design/Ideas/Reviews 6 3rd July 2004 01:12 AM
variable 5,10,15,20 minutes timer circuit james Electronic Projects Design/Ideas/Reviews 3 24th October 2002 03:24 PM
