i am trying to run a 5 volt chip that draws 30mA from a 24 volt transformer. this is how i calculate it. 24 volt ac rectified and filtered 24 * 1.44=34 volts dc 34-5=29 volts to be dropped by the regulator so 29v * .030A =.87W that the regulator will have to dissapate. will a lm7805 be able to handle this? I don't think they can drop that much voltage but don't understand why. | |
the datasheet i have for the Fairchild LM7805 says Vin <= 35vdc for under 7818 and below, and 40v for over 7818 and above. so 29v is technically within the specs, and at 30mA, a big beefy (and inexpensive) to220 regulator shouldn't have any problems might want to look at ldo regulators, something in a sot-223 or super sot3 package if 30ma is all you really need.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
If you do use surface mount regulators, pay careful attention to the design guides. 0.87W can be a lot for a tiny package. For the Fairchild LM7805, the quiescent current with 25V, (no value given for 34V) is typically 6mA, adding 0.204W (or more) to the total. A bare TO-220 can handle almost 2W in free air, but it'll feel awfully warm even with 1.07W. The case will be between 90 and 100c. | |
Hi Gaston, A standard 7805 or LM340-5 would do the job but if you feel a bit uneasy about it you can always use a 7824 to preregulate the input voltage of the 7805 to 24 volt and also bring down the dissipation of the 7805 to a more moderate level. (19 * 35E-3) Alternatively you could take a look at the datasheet of the TL783. http://www.alldatasheet.com/datashee.../TI/TL783.html on1aag. | |
What voltage does the transformer give when no load is connected? About 28V? That will give a bit more about 40V which is too much for the LM7805. You could use an LM317 and add two extra resistors and can handle a voltage drop of 40V.
| | #6 |
do they make a switching regulator that may be able to handle it a little better?
| | #7 |
Sure. A lot of them are great for this job. LM2575 has been around a while and is cheap ($1.21 @ 1K).
| | #8 | |
http://www.romanblack.com/smps/a03.htm
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #9 |
24*1.414 = 34V Subtract the votage drops in the diodes = 32.4V which is below the 35V maximun rating. It's going to get really hot though. | |
| | #10 |
sorry .. i got the 1.44 wrong and forgot to subtract the diode drops. thats why i like to post my math in case i make a mistake someone can point it out. thanks. so is .87 watts a lot of heat for a to220? i didnt see in the datasheet where it specified wattage. how do you know how hot that is? just from experiance i guess?
| | #11 |
the data sheet puts thermal resistance to air at 65C/w ... so lets round your .87 up to 1w ... that means the body of the regulator will increase 65C over ambient with 1 watt of power dissipation. If you're in a cool room, 25C, that's well withing the 125C operating temperature. Even if it is hot out, like 35C, you're still within spec. however, 90-100C is damn hot. even a small heat sink would make the regulator safer to work around, in case you touch it, you don't get a nasty surprise.
| | #12 |
so just add 65c per watt over ambiant temp and that gives you the temp?
| | #13 | |
| | #14 | |
| | #15 |
You could do but is it really worth it for just 30mA? I'd go for the LM317 if I were you.
| chip, transformer, volt |
| 24 volt output, 12 volt charger | bigpaddy_irl | General Electronics Chat | 7 | 14th November 2007 05:48 PM |
| Digital to analog converter chip | vuchris | Electronic Projects Design/Ideas/Reviews | 6 | 16th October 2007 10:02 AM |
| Problems selecting a PCB Transformer | NewcastleSAR | Datasheet/Parts Requests | 31 | 4th January 2007 08:16 PM |
| Transformer + battery = School Thrills | windozeuser | General Electronics Chat | 3 | 14th December 2005 10:28 PM |
| Chip Identity | edcross1 | General Electronics Chat | 5 | 21st July 2005 08:52 PM |
