Old 5th February 2008, 12:21 PM   (permalink)
Default Ac to DC
Hey,
When converting form AC to DC through a rectifier-bridge, is't nessasary to use a cap to reduse the ripple, right, I'm wonder how big does it have to be? are there a formula? its up to the load right? And do I also need some filters to remove unwanted noise?
And the dc voltage is the AC peak?! so 24VAC is about 31VDC?
johannes
jdahl is offline
Old 5th February 2008, 12:38 PM   (permalink)
Originally Posted by jdahl
Hey,
johannes
Yes what you say about the output voltage of the bridge is pretty close when considering the voltage drop of the bridge rectifier. To calculate the value of the filter capacitor need, you must have load current,and the maximum ripple voltage. This formula works pretty well:
Vripple= Iload/(2FC).
Where Iload= load current
F= mains frequency in hz
C= capacitance in Farads.
k7elp60 is offline
Old 5th February 2008, 04:11 PM   (permalink)
F= ripple frequency in hz(with a full wave rectifier=twice mains frequency)
F is the mains frequency, not the ripple frequency. You have already accounted for the frequency doubling with the '2' in the equation. This gives you a very conservative answer. The ripple will always be less than the equation predicts.
Ron
Roff is offline
Old 6th February 2008, 02:58 AM   (permalink)
Roff is correct, I have edited my post. I have used a rule of thumb of 3000uF/A of load, and recently found this formula and found it interesting.
I would assume that this formula is for a full wave rectifier.
k7elp60 is offline
Old 6th February 2008, 03:29 AM   (permalink)
Simulators are better than a formula. Essentially because they are *lots* of formulas.
http://www.duncanamps.com/psud2/index.html
Best power supply designer I've found.
speakerguy79 is offline
Old 6th February 2008, 04:35 AM   (permalink)
I'll try to explain the equation, and its shortcomings:
The capacitor charges through the rectifier until the sine wave peak passes. Then the diode becomes reverse-biased, and ceases to conduct. The capacitor then starts to discharge (assuming a constant current load) at the rate of v=I*t/C. At some point during the discharge, the voltage on the anode of the other diode in the rectifier becomes more positive than the load voltage, causing the cap to begin to charge again. If the discharge had proceeded for a complete half cycle (that's the "1/2F" term in the equation), the equation would be exact. However, as I said, the discharge ramp is terminated when the rectifier gets forward biased. As the ripple gets larger, this happens earlier in the half-cycle, causing the calculated error to be greater as the ripple increases.
Did that make sense?
Ron
Roff is offline
Old 6th February 2008, 05:32 PM   (permalink)
Thanks Roff, I understand what you are saying.
k7elp60 is offline
Old 6th February 2008, 05:33 PM   (permalink)
Hey,
johannes
It depends on what you're powering.
A DC motor doesn't need a filtering capacitor.
A regulator does and it needs to be large enough to ensure the voltage does not drop below the lowest input voltage required for it to regulate properly.
Screen name: Aloone_Jonez
Hero999 is offline
Old 6th February 2008, 05:41 PM   (permalink)
I thought you were referring to the rock band.
quixotron is offline
controll ing dc motor need help norms09 General Electronics Chat 14 5th August 2008 12:36 PM
Inverter DC to AC... yiefang Electronic Projects Design/Ideas/Reviews 7 12th May 2008 01:51 PM
help needed on dc motor raviram87 Robotics Chat 6 12th January 2008 12:05 PM
Ac bridge vinke General Electronics Chat 24 2nd December 2007 04:24 PM
Convert 12V DC to 220V AC micpic Electronic Projects Design/Ideas/Reviews 17 15th September 2007 02:03 AM
