Old 4th February 2008, 01:34 PM   (permalink)
Default I need your help to catch an intruder!! Solar security camera project
I am a real amateur when it comes to all things electronics and I was wondering if you could help me.
I have purchased land out in the middle of bush in south queensland and have no power. Unfortunately I have had a fair share of red necks helping them selves to things on my property, or just simply snooping around when I'm not there.
Due to this, I have recently purchased a digital camera that runs off a 9volt battery. It takes a photo when motion is detected with the inbuilt motion sensor, and saves the image on to an SD card. Works an absolute treat for my intentions. However, the 9volt battery only has a life span of about 7 hours.
I need to have the camera continually running while i am away from the property (sometimes up to 1 month). I was considering hooking a solar panel directly to my 7aH 12volt battery, reducing the voltage down to 9v and plugging straight into the camera.
Will this work?
I currently have a 1.5 watt solar panel that i intend on using for the project, will this have enough guts to keep the battery powered? (this panel will get maximum exposure to queensland sunlight if that makes a difference)
If not, can you please tell me the best possible way of achieving my outcome.
Appreciate your help,
here are the below specifications of my camera.
Imaging Sensor: 1/ 4" Color CMOS sensor
Lens: F2.0/f3.6(4G+IR) pinhole
Resolution: 640H x 480V (4:3)
Responsively: 1.9V/lux-sec(550nm)
Dynamic Range: 60dB
S/N Ratio: 45dB
White Balance: Automatic
Exposure: Automatic
USB: 30 frames per-second
Power Supply: 8~14VDC
Current Consumption: Standby@12V~50mA
Max.(Alarm)@12V~50mA
Operating Temperature: 14°F ~140°F / -10°C ~ 60°C
Fire Protection: ABS plastic housing
ashton86 is offline
Old 4th February 2008, 02:53 PM   (permalink)
Looks like you can run it at 12VDC from the specs.
I would drop the panel on the battery, get a meter, make sure in bright sunlight you are under the 14VDC, and run it from the battery.
mramos1 is offline
Old 4th February 2008, 06:08 PM   (permalink)
Why start a new thread?
Whay not ask this in one of the other threads you started?
Screen name: Aloone_Jonez
Hero999 is offline
Old 4th February 2008, 08:07 PM   (permalink)
I did think there were a lot of security camera posts for this forum today.
Home sick, so popping in more than normal.
Ashton, just post one message, people will help. Multiple ones and they will ignore you.
mramos1 is offline
Old 4th February 2008, 08:35 PM   (permalink)
You once had a 5W panel which would probably have been enough. 1.5W is not.
mneary is offline
Old 5th February 2008, 08:04 AM   (permalink)
thanks for your help.
i have been advised that a 1.5watt solar panel will be enough to charge the 7ah battery if placed in direct sunlight.
do i need to worry about over charging or discharging? or will the built in diode (in the solar panel) be enough for this project
ashton86 is offline
Old 5th February 2008, 12:51 PM   (permalink)
I don't think it's large enough to over-charge anything, but I would have thought it's far too small for your requirement?.
Nigel Goodwin is online now
Old 5th February 2008, 01:12 PM   (permalink)
What will you do when they steal the camera? A solar panel will [probably] be easy to spot.
Jeff
jbeng is offline
Old 5th February 2008, 08:28 PM   (permalink)
If you get their picture, what will you do with it?
mneary is offline
Old 5th February 2008, 09:17 PM   (permalink)
Why not lock everything up? If it really becomes a problem call the local authorities.
Krumlink is offline
Old 5th February 2008, 10:34 PM   (permalink)
I somehow get the feeling Krumlink lives in a city!
Old 5th February 2008, 10:40 PM   (permalink)
Actually I live way out in the country, farms and cows here.
Krumlink is offline
Old 5th February 2008, 10:45 PM   (permalink)
Just a thought, but if a 9 volt gives you 7 hours, how long would a 12v lead acid car battery give you? That would be easier then the solar option. You would just have to charge it with a generator during visits, or take it home to charge and leave a charged one in its place.
This message transmitted on 100% recycled electrons
Andy1845c is offline
Old 5th February 2008, 10:48 PM   (permalink)
Jeff
Does it have a flash? Does it work at night? Even if you hide the solar panel and camera from view, if a flash goes off, the trespasser will know he has been photographed an will possibly destroy the camera so that you don't see the photo.
Old 5th February 2008, 11:19 PM   (permalink)
Talking
Nope no flash, pretty much only designed to work in the day. The camera is certainly well hidden and i doubt that even if the intruders do find it, they probably wouldnt know what a camera does!
I have rigged up a motion sensor solar security camera near the camera to act as a flash at night time. This seems to work a treat.
Hopefully I'll have some pictures so post up on here on my next visit out bush. I plan to give a copy to the local police but also to keep one printed and enlarged on the door of my shack. I think the shear thought of having their picture taken out in the middle of no where will trip their imbred minds enough to stay away (or burn down the place)
Cheers for your help
ashton86 is offline
First Bigish Project: Sun tracking solar panels. Grompus Electronic Projects Design/Ideas/Reviews 5 8th February 2008 03:08 AM
GPS Speed Camera Warning Project cx1 Electronic Projects Design/Ideas/Reviews 7 4th January 2006 12:53 PM
Motor Camera Control Project! CircuitMan Electronic Projects Design/Ideas/Reviews 1 22nd November 2004 06:29 PM
Camera and Display project Shahzad73 Electronic Projects Design/Ideas/Reviews 0 26th October 2004 09:32 AM
Motion sensing/tracking security camera project cool-agent Electronic Projects Design/Ideas/Reviews 5 28th April 2004 06:03 PM
