+ Reply to Thread
Results 1 to 11 of 11
Thread: Complete beginner!
  1. #1
    stuz Newbie
    Join Date
    Feb 2008
    Posts
    1
    Default Complete beginner!
    Hey everyone! Love the forum, I've been a lurker for a bit too long to be honest!
    Anyways, my name is Stuart- I'm a technology student at the University of Glasgow. And like I'm sure a lot of you guys have done, I've recently started getting electronics lectures, tutorials etc. So I have a VERY basic knowledge but I'm eager to learn (hence joining).
    I was actually wondering if anyone here could give me a hand with a project I'm working on just now, it should be REALLY simple for you guys looking at some of the depth that some things have gone into!
    I'm currently designing a clock in my design class, and we have to make a working prototype of our model. The design that I have is basically a laser like >>this<< one which is on a unit on the ceiling which slowly turns, the time is then indicated by where the laser dot is pointing to on the wall.
    The problem I have had is that clock mechanisms are very fragile, and dont have enough torque to turn the weight of the motor round. So I decided that a DC motor would be far better to do this. The problem I have however is that they turn severeal hundred revolutions per minute! Not the 0.08 revolutions per hour that I need it to do in order to tell the time! Now I know that if you half the voltage going into a stepper motor, it halfs the RPM. So could I just have a circuit containing only a power supply, a big enough resistor, and a motor and set the speed from that?
    Because it is only a prototype, it does not need to extremely accurately be able to tell the time, however I cant have it spinning a laser round at 200rpm! I just need to slow it down enough to give our lecturer a picture in his head of how exactly the product would work.
    Someone suggested a stepper motor to me, but are they not very expensive and do they not need to be computer programmed?
    Thanks for reading guys, any help will be really appreciated!
  2. #2
    rjvh Excellent rjvh Excellent rjvh Excellent rjvh Excellent rjvh Excellent
    Join Date
    Dec 2007
    Location
    cambodia
    Posts
    865
    i would solve it mechanicaly and reduce the rpm (if the difference is verry big)
    with 2 disc s and a rubber string like in the old tape recorders or turntables,
    if you don't want to have anny mechanicaly slipp work with sprocket chain or sprocket to sprocet conection
    still a chance that you have a fall back from the top dead point problem
    if you don't want that work with a sprocket wormweel configuration
    with all methodes you will increase torque so you don't have to worry about that
    sucsess with your project
    Robert-Jan
  3. #3
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,170
    I agree, do it mechanically.
    If you try to reduce the speed electronically, you'll get to the point where the torque is too low to move the shaft, even if you used PWM.
    if I know the answer.
  4. #4
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,724
    Stepper motors are not controlled by voltage, they are controlled by frequency. A microcontroller would be the best way to control one. If this is beyond your capabilities, you should do it mechanically, as others have suggested.
    Actually, if you have a laser with enough power, you could spin it at a higher speed, and turn it on at the appropriate times. But that would probably be best done with a microcontroller.
    Ron
  5. #5
    picasm Good picasm Good
    Join Date
    Sep 2006
    Location
    UK
    Posts
    358
    You could try using a mains synchronous motor. These are usually found in mechanical mains timers such as this one:
    http://www.maplin.co.uk/Module.aspx?...=timer&doy=4m2
    They should be accurate enough for what you need because they sync with the mains frequency and they are geared-down when used in timers etc.
  6. #6
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,170
    The permanet magnet synchronous motors generate high voltages when the shaft is moved and are good fun for shocking people with.
  7. #7
    Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Quote Originally Posted by stuz
    Maybe I'm misunderstanding this, but could you perhaps just mount a little mirror on the spindle and bounce the laser beam off that? Laser (and other aimable lighting) effects units don't usually move the heavy lamp but rather just move a lightweight mirror.
    If you can find a tiny little chunk of mirror which the motor can spin then you don't have to mess around with the mechanics of the thing and can just use it as-is.
    Then again, I've only had the one cup of coffee today so take that into account.
    Torben
  8. #8
    Mike odom Newbie
    Join Date
    Feb 2010
    Posts
    119
    Quote Originally Posted by picasm View Post
    7 Day Plug-in Mechanical Timer : Timers : Maplin
    Mechanical timers like this are extremely accurate, simply because they are AC motors tied to the mains, which are kept at a precise 60Hz (over the course of 24 hours they average 60 cycles per second) and keep better time than a $10,000 Swiss movement watch!! Of course, they keep better time than say, a computer, which uses a crystal time base which has an accumulated error over time (unlike the mains). You may not notice it on your computer, as they sync up when you get online and correct the time. But a standalone machine will accumulate an error that will probably be noticable within a week.
    Stepper motors are driven by 'stepping' through a series of coils (either 2, 3, or 4, depending on the motor) at the frequency you want to run the motor at. Trying to drive a DC motor at the correct speed is hard enough to do at full voltage, let alone when you try to tweek it down to run really slow, not a good idea. They do have stepper motor controllers that take a DC input so you wouldn't necessarily need a micro to run one, but I don't know how slow or how accurately they'll go without researching it.
    I like the rotating mirror design myself, but good luck figuring out the angles and dangles of having a fixed light source and projecting the dot around this perimeter over there!!!! Seems the light source would have to be in the middle and deflected around to get the positioning correct. Maybe two mirrors, one to deflect the light source from a side to the center, and then one rotating to reflect it out to where it needs to be.
    Interesting project. Keep us posted...
  9. #9
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,724
    Mike, you need to look at the dates of the threads you are replying to.
    Ron
  10. #10
    Mike odom Newbie
    Join Date
    Feb 2010
    Posts
    119
    er, um, YA... I see that now... I just stumbled onto this forum last night... looking for injector control circuits... THANKS for the insight...
    besides, better late than never...
  11. #11
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,724
    Quote Originally Posted by Mike odom View Post
    Don't feel like the lone stranger. A lot of newcomers do the same thing.
    Ron
+ Reply to Thread
  1. As a Beginner
    By ruzfactor in forum Micro Controllers
    Latest: 5th January 2008, 06:38 PM
  2. Good Beginner Micro Controller
    By psecody in forum Micro Controllers
    Latest: 29th January 2007, 01:59 PM
  3. Questions from a beginner in electronics...
    By Shocks McTool in forum General Electronics Chat
    Latest: 21st November 2005, 02:01 AM
  4. beginner in microcontrollers
    By lordsathish in forum Micro Controllers
    Latest: 6th June 2005, 01:18 PM
  5. Complete Beginner
    By noctorum in forum General Electronics Chat
    Latest: 15th October 2004, 03:57 PM
Tags for this Thread
