| Dear all, I'm trying to build a controller system for a heating system, based on a microcontroller. I would like to actually implement a PID control instead of an ON-OFF one by using a temperature sensor and controlling the RMS current of the heating element using the PWM output of the controller and a .... And here is my problem! I need to be able to PWM the current of a 2kW heating element, but I fear (maybe wrongly) that the current is a bit high to use a TRIAC on an inductive load. I have also thought of using an IGBT or thyristors in anti-parallel. But in reality, I have a tough time deciding which is the safest, easiest way to go. What would you recommend? | |
| What about using a large solid state relay? I have seen them used in electric thermographers to contol the heating elements.
__________________ This message transmitted on 100% recycled electrons | |
| A quick search shows Triacs as large 100 amps. There are many in the 40 amp 400 volt range and 20 amp 400 volt. Use a triac. | |
| A pure heater isn't inductive, but you'll definitely need a filter to control interference (The filter will contain moderately sized inductors). I'm guessing that at 2kW you'll be controlling 220VAC, which is only 10A. A 20A triac, properly heat sinked, is easily accommodated. | |
| normaly if the triac is properly cooled (you better can over do it than to less) it should not be a problem make sure you get at least a 600V triac (220V AC is peak to peak is 440V) a 47 nF capacitor and a 100 Robert-Jan | |
| I've quickly checked the controller specs, and I do not think that it can as low as 100 Hz for the HW PWM output, which either leaves me two possibilities (I think): Soft PWM using a triac (Do I need a snubber circuit of some sort? I've never measured the cos phi of a standard "commerce" 220V heater) Using an IGBT connected to the HW PWM output, cycling at perhaps 1kHz. However, I fear that I need to install RFI filters on the mains side to avoid pumping the house mains full of harmonics, and probably some filter on the heater side to avoid having the harmonics break the insulation (as happens in "unprepared" motors when using a frequency converter). Am I missing something here? | |
I guess I can use a triac triggered at the "right" part of the cycle (is that what burst-fire means?), but I would need to "track" the cycle or at least synchonize the controller with it, right? Is there a way around this? I have this heater controller project, but I'm also trying to learn. So, I have one further question: Why can't you "chop" AC with an IGBT suing PWM at a frequency that is a multiple of the mains to get a lower RMS voltage (and lots of harmonics, that is for sure)? | ||
| | (permalink) | |||
| Umm... If it's a plain old heating element, why can't you just use DC? I'm sure the heater rectifies the AC anyway? Mains is 240VAC-RMS so you need 240VDC, which can be achieved by rectifying the mains - although this will result in a voltage slightly higher than 240V it shouldn't do any damage to your heater. You could then just PWM it with a FET? Correct me Nigel/Someone Else if what I've suggested will result in pyrotechnics.
__________________ What is a joule per second? | |
Like I said though, PWM'ing isn't the way to go, it gives no advantages, and lot's of disadvantages. | ||
| Thanks a lot for the clarifications! Quote:
How could I implement a circuit that gives me a TTL 0 (or 1) when the mains are at zero crossing (to avoid using an A/D converter)? | ||
| Zero-crossing is simple to do, and certainly doesn't require an A2D, here's a simple method I posted ages back. | |
| Would a zero crossing detector be of any use for extending relay contact life? | |
| Triac light bulb flasher | ElectroMaster | Electronic Projects | 17 | 30th July 2008 04:20 PM |
| Triac problem. | robyelectron | Electronic Projects Design/Ideas/Reviews | 0 | 2nd August 2005 12:15 PM |
| triac connection | Hihi | Electronic Projects Design/Ideas/Reviews | 4 | 5th July 2005 09:31 AM |
| 555 Triac MAC15SM | pop | General Electronics Chat | 4 | 6th March 2005 02:06 PM |
| Building a traffic light pattern and Im stuck (triac help!) | oxygen454 | Electronic Projects Design/Ideas/Reviews | 10 | 20th December 2003 04:30 AM |
