+ Reply to Thread
Results 1 to 2 of 2
Thread: power supplies.
  1. #1
    SeanHatch Newbie
    Join Date
    Dec 2002
    Location
    Michigan, USA
    Posts
    97
    Default power supplies.
    I need a power supply which converts mains ac to a high frequency (about 20khz) square wave. At first I did a normal linear power supply: xformer--->rectifier--->limiter then I used this as Vcc for a 555 timer. Done deal.
    Now I'm reading about switching power supplies. They have some nice qualities, but It seems like it'd go something like this: rectifier--->inverter--->isolation xformer.
    The thing is, wouldn't the inverter require a 555 timer, or something similar anyway? Is it really worth switching power supplies just for a smaller xformer?
  2. #2
    stevez Good stevez Good
    Join Date
    Apr 2003
    Location
    Rochester, NY
    Posts
    2,115
    In general, the industry has moved to switched mode power supplies for at least two reasons - and the bottom line is probably a cost advantage. The two reasons I can think of - size of the transformer and efficiency. One might think of efficiency as being less important if you are plugged into a wall but less efficiency means more heat - more heat means more need to manage that heat in a system or product.
    If you are making your own power supply then the cost/benefit analysis is likely to be unique to your situation. For the do-it-yourselfer it's hard to beat the simplicity of a transformer, rectifier, capacitor and 3 terminal regulator. Plenty to learn by this approach and lots more to construct a switched mode supply. National Semiconductor has a nice website and design tools - never actually built one but you might give that a look.
    stevez
+ Reply to Thread
  1. Understanding TV power supplies
    By tab a in forum General Electronics Chat
    Latest: 27th December 2007, 09:06 PM
  2. Multiple output power supplies
    By jnnewton in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th December 2007, 05:05 AM
  3. Push Button On/Off power to PIC
    By eblc1388 in forum Micro Controllers
    Latest: 17th February 2006, 02:32 PM
  4. Paralleled Power supplies
    By ALARMED in forum General Electronics Chat
    Latest: 22nd May 2004, 05:12 PM
  5. Power Supplies
    By Kane2oo2 in forum General Electronics Chat
    Latest: 22nd November 2003, 07:42 PM
Tags for this Thread
